Results 1 to 15 of 15
    Jan 2005
    Fort Lauderdale
    Dry-stack my looper.
    Hey guys. I've got my 2000 200Johnson apart right now and decided I might as well dry-stack the motor while the powerhead is off and mid is on the floor of my shop. I just wanted to get some tips on what works best and what to do/not to do. I tried searching and got quite a few threads on the subject but most were really old and I was curious if there was any "new innovations" out there.
    BTW my motor is a near stock 200 HO motor with mid-bores. Milled heads 125-130 lbs.compression. New style gutted airbox. Relieved exhaust. Nothing too fancy. I usually turn my 30 chopper 6400-6500 RPM.
    Jan 2005
    Fort Lauderdale
    Also, any other quick hop-up tips you guys wanna throw my way while my motor is apart, my ears are open.
    THANKS.
    Nov 2007
    Tarpon Springs FL/ Queens. NY
    Donno how to do it but mine is dry stacked i bought an adaptor that was done already... i can tell you it sounds and looks sweet( i think)
    heres mine
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/c18WvN2acGk&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/c18WvN2acGk&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    Mirage RR
    Lake Tarpon Boyz!!!
    Dec 2004
    Key Largo, fl
    that thing idles high!
    1988 reaction19-sold
    1978 action20 w/ 250 efi-sold
    2003 quartershot T4-sold
    1978 16 action with 15'' 2.4 -sold
    1979 mako21 w/ evinrude 150 faststrike-sold
    1995 18 ACTION COPY w/ CCMS HO2FO!-sold
    1981 24' manta w/ a v8
    Nov 2007
    Quote Originally Posted by Reaction19 View Post
    timing is fully advanced... helps when you stab the gas it doesnt hesitate as bad if at all....
    Mirage RR
    Lake Tarpon Boyz!!!
    Antioch, IL
    Not to mention it's running on a hose...
    Sam Baker
    On to the next project....
    it idles at 1200 in gear with the 30 chopper II in the water
    Lannon WI
    Just use the washdown button to control the idle
    2006 Action Marine Comp
    1980 Ventrua 2
    Dec 2004
    Key Largo, fl
    gotch what should a 225 looper idle at on the hose, and how do you adjust it, just wondering as my bro in laws motor idles low in gear and stalls frequently, idle in gear is roughly 550-650 sometimes when you stab it it feels like theres no fuel going into the motor it just boggs and stalls, carbs are clean, and it has a hollyred, with a claen filter. sorry to steal the thread dave, but their's alot of omc guys lurking in here at one time, figured i'd pick their brain.
    Nov 2007
    theres an adjustment on the left side of the motor if your looking at the front of it, under the fly wheel, use a flat head to adjust it... believe counter clockwise it advancing it... could be wrong... start the motor and use a long flat head and play with it
    Mirage RR
    Lake Tarpon Boyz!!!
    Dec 2004
    Key Largo, fl
    thanks.
  12. #12
    Nov 2007
    Mirage RR
    Lake Tarpon Boyz!!!
  13. #13
    Lannon WI
    Just be sure the throttle plates are fully closed on all cylinders when adjusting the Idle. If the plates crack open then there will not be enough signal to pull fuel threw the Idle passages correctly.
    1980 Ventrua 2
  14. #14
    Quote Originally Posted by Laker View Post
    word
    beef doesnt know what idle is WFO or its on the trailer
  15. #15
    Nov 2007
    word
    Mirage RR
    Lake Tarpon Boyz!!!
