Results 736 to 750 of 977
02-03-2009, 06:50 PM #736
02-03-2009, 07:33 PM #737
02-03-2009, 07:36 PM #738
02-03-2009, 08:24 PM #739
It needs to idle out of the sand bar at least. Without dying three times. So you guys are thinking its fat on idle?
Rick
02-03-2009, 08:34 PM #740
Beef
Dont be afraid to post some gps #s on the action wit tha loopa.
02-03-2009, 08:37 PM #741
64mph gps is all lots of ski time on this motor also has a 23 four blade
02-03-2009, 08:38 PM #742
02-03-2009, 09:01 PM #743
Im going to raise the motor an inch this spring.I think its to deep no rooster tail ?
02-04-2009, 09:42 AM #744
02-04-2009, 09:45 AM #745
Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
Mine wouldn't idle either when warm. Turns out one of the reeds was held open by a burr on the reed block. Bad reeds can surely cause idle difficulties.
02-04-2009, 09:56 AM #746
02-04-2009, 10:00 AM #747
- Oct 2003
- Cobourg, ON
- 7,194
Yeah a bit, but I was told that was normal. It was probably a combination of things. The idle got a little better when I added exhaust reliefs. I brought the mid to work today to open up the relief slots a little more, to slightly larger than stock, which is two 1/2" holes.
02-04-2009, 10:07 AM #748
I would do a complete link and sync including checking idle timing and indexing the flywheel. I would bet something is off a little.
Ralph Musser
27' Fountain Fever W/ 525SC
22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
24' Triton 240 Gold W/ Mercury 60
14' Royalcraft W/ Evinrude 75 father/daughter project
02-07-2009, 07:25 PM #749
- Oct 2003
- Cobourg, ON
- 7,194
Some of the many upcoming improvements....
Put the mid on the milling machine today to remove some excess material. Took off up to 1/4 inch in this pic!
Opened up the idle relief slots for a little more flow.
Got a later model pan ('95 I think) with the trim switch and I'm in the process of adding rigging tubes. I haven't started grinding on the epoxy yet.
02-07-2009, 07:31 PM #750
Looks like you're having some fun Jeff.
Ló fasz racing
Joe Horvath
Its NOT the ignition coils causing bad Idle.
.... got a 32 cleaver want to try, supposed to be good for that boat top end wise and the limiter shouldn't be ther much longer... we'll see
