Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 16 to 30 of 153
    May 2005
    Buffalo MN.
    I'm glad part of this post was deleted.
    V-king jet boat
    Seadoo speedster 200 310hp
    Hole shot http://s5.photobucket.com/albums/y16...t=MOV00922.flv
  2. #17
    Prince George B.C. Canada
    Sounds like your having fun getting her going. Thats awsome your right into the boating scene. Dont take things to heart. This is the best high performance boating site on the net hands down as mentioned. I think the best thing ive noticed on hear is theres a lot of world champions, High points Champs,world record holders, Extreamly fast boat Manufacturers ect.That post every day on hear. Your attention grabbing 60mph thread then only posting 40 is,well,You Know what I mean. You seem like an enthusiactice fellow boater keep up the good work and lets see some pics man!Pics are always sweet!
  3. #18
    Sarasota, FL
    Quote Originally Posted by xr1million View Post
    I didnt come on here saying I know anything, just having fun with this... I guess this forum is like every other one on the net.
    Unfortunately it is.
    There ya go guys ...run off another one just while he starts to have a little fun
    Good luck with the Fliver
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  4. #19
    Sep 2008
    old exit 73, Florida
    Quote Originally Posted by whipper View Post
    The 40 was with the motor being bolted on 15 minutes before, have yet to mess with trim (because I must unbolt the motor to change pin position) or height. I WILL be over 50 today... I hope
    Maybe I should change the title to "my quest of a 60+ mph fliver"
  5. #20
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    seen to many come and die,
    Quote Originally Posted by Hot Shot Merc View Post
    there are consiquences for your actions, mechanical engineering and physics are two compleatly differnt thought process.
    most overnite successes usually take at least 10 years
    Certified turd polisher,
  6. #21
    Sep 2008
    Quote Originally Posted by mr fun View Post
    Right you are Kent!
  7. #22
    thats Clark Kent,
    Right you are Kent!
  8. #23
    Sep 2008
    I was more going for Kent from MXC...
    whoops looks like my hearing let me down again, its Kenny.
  9. #24
    Yeah, that would have been a better title. If you want to know why it is unlikely just ask and I will explain the problems you will have to overcome.
    You are making a good start in high performance boating, but you seem to be choosing the long route of learning each part from personal experience rather than other's.
  10. #25
    Sep 2008
    Alright Jonny boy, what will I have to over come??
  11. #26
    Sep 2008
    yes I know the skeg is broken, I have another motor that I going to use the housing from.
    I believe the inspiration for who ever built the Fl skiff was a fliver... almost same hull design just twice the size
    and looking for a trailer locally!
  12. #27
    Sarasota, FL
    Fun....Its all good.Just posting my humble opinion
    Rob Lankford
  13. #28
    wow compleatly over my head,
    must be some rap videogame about bicycle daredevels, been busy in bigboy world i guess.
  14. #29
    (1) Propellor availability. Since motors the size you are using aren't generally used at the speeds you are trying for, no one makes a prop for your goal. Even bending the max pitch available won't get you over 50 mph. Look at your current pitch, max motor rpm and gear ratio; find a speed/prop pitch calculation and put in your data with about 20% slip. The motor is going to max out and not just rev forever ... don't get it in your head that you can just call up 10,000 rpm because you want it. Realistic max rpm might be 6,000 or so.
    I hope you've already learned that props can only be altered about 2 inches of pitch from their produced base pitch. Some props are already stretched to be finished at the additional 2 and won't go any farther. There are 2 ways to overcome this ... finding a prop shop that can cut the blades off and competently reweld them on at a steeper angle or finding a prop with the desired pitch and some how adapting it to your shaft.
    (2) Possibly around 50 mph with the altered prop you will hit the "hp available vs hp needed for load" intersection. These are a pair of exponential curves that come at each other very quickly at the end. The next problem comes from how much motor the boat will float vs how much power is needed to go faster.
    (3) Stability. The boat is not going to be stable at your goal speeds. You might see the goal speed just as it spits you out.
  15. Likes wolfgangb liked this post
  16. #30
    Sep 2008
    carolina skiff Einstein?
    Uhh NO, but that just removed all doubt that ,you sir... are a JACK ASS!
    It is a Florida skiff they are made down south somewhere!
    Carolina has never made a flat bottomed tunnel hull!
    Florida skiff is only making v-hulls now.
