Results 1 to 15 of 21
    JUPITER, FLORIDA
    What's faster? Hydrostream YT, XT or ZT bottom??
    Here's an interesting thought or test! What's faster....the Hydrostream YT, XT or ZT bottom??? I know the YT is probably the easiest to drive being that the sponsons are about even with the center pod pad and they are part of the planing surface..but how bout the XT bottom with narrow sponsons that are higher than the center pod or...the ZT where the sponsons are lower than the center pod and act more like a tunnel???
    Paramount 21/Merc 225 EFI
    Cobalt 263/VP 8.1L
    Nova Spyder 230/454 Mag
    Barracuda 188CCR/Suzuki 140
    Checkmate 2800SX/Twin Merc 250’s
    Checkmate Pulsare 2400/Verado 300
    Checkmate Starflite/Merc Pro XB250
    Canadian Edition Hydrostream AE-21/Merc 2.5
    Checkmate Pulsare 2100/Merc 225Xri
    Hydrostream Valero YT/Merc 175
    Talon T-21/Mercury 245hp carb
    Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
    Velocity 230/454 Mag
    Scout 172 Sportfish/Yamaha 130
    SeaRay F16 Jet boat
    SeaRay 17' Seville
    Feb 2008
    Castle Rock Lake,Wisconsin
    The Xt is faster with added wieght ,carries it more efficient ,more like a vpad on all out running surface.
    JUPITER, FLORIDA
    It would be interesting to take all three hull designs in the same length and run them with the same horsepower motor. It would make for a good writeup!
    Cobalt 263/VP 8.1L
    SeaRay F16 Jet boat
    SeaRay 17' Seville
    Lake Coochiching, Ontario
    The ZT sponsons are not deeper than the YT, but they are wider.
    There is no 20' YT or ZT version.
    There is no 18' XT.
    Unless someone pays for tooling, we'll never know.
    Jun 2004
    port st. lucie, fl
    steve, you could almost have answered your own question(well 2/3 of it)!!! kevins boat (vegas xt) my boat(virage zt)-we purchased identical engines(came off twin eng boat), mine went 104 w/ no real work on the setup, kevins goes 102, with more effort and tuning and minor mods to the engine i got to 109, now kevins vegas could prob. go faster w/ some tuning
    Feb 2008
    Do the different stages on the virage make a differance for speed or just handling???
    JUPITER, FLORIDA
    Quote Originally Posted by mrcrsr View Post
    Hey Charlie...I guess the comparison would be harder to figure out..there's a big difference in the weight/width/length of the Virage/Vegas/Valero YT/etc.
    mmm...we should've slapped one of those motors on my Valero YT to see what would have happened!! .....though I don't think I would've wanted to drive a 17'9" boat at over 104 mph!!!!! I know the Virage ZT is a wider version of the YT bottom but the Vegas XT is completely different.... I still think it would be cool to try all the hull designs with the same power plant to see what would happen. We could even throw in the V-bottom to the mix!!
    Cobalt 263/VP 8.1L
    SeaRay F16 Jet boat
    SeaRay 17' Seville
    JUPITER, FLORIDA
    Quote Originally Posted by king gill View Post
    The last version (I think they called it a Turbo stage III) was supposed to be faster. Stream notched out the sponsons to reduce the wetted surface thereby reducing drag and allowing the boat to plane off sooner....
    Cobalt 263/VP 8.1L
    SeaRay F16 Jet boat
    SeaRay 17' Seville
    JUPITER, FLORIDA
    Quote Originally Posted by David View Post
    There is no 18' XT.
    I could be wrong..but I think the center pod on Charlies Virage is higher than his sponsons....but it's been a while since I looked under his boat. Hey Charlie, chime in on this one! I know my YT sponsons are even with the center pod and I know the Kevin's Vegas XT has very narrow sponsons that are higher than his center pod.....
    Cobalt 263/VP 8.1L
    SeaRay F16 Jet boat
    SeaRay 17' Seville
    Oct 2003
    Rome, NY
    Quote Originally Posted by JUPITER PULSARE View Post
    Just going off what I remember reading from this site... I believe a Viking YT has gone in the 110-112 range, Helmut in a Virage has gone 115.4? I believe and I'm not sure I've read of an XT hull breaking 110...
    -Duane
    Clarkson University Graduate (Finally)
    68/69 V-131(or 141?) Checkmate...
    Quote Originally Posted by Raceman View Post
    This clown isn't qualified to be a janitor in my business.
    Quote Originally Posted by Liqui-Fly View Post
    Only a libtard...
    Each stage of the Virage got faster. The Turbo was faster than the non Turbo. We're only talking a couple of mph here.
    http://www.hydrostream.org/Specific%20Models/Models.htm
  12. #12
    Jun 2004
    port st. lucie, fl
    the pad is slightly below the sponsons(i think 1/8"), there supposedly wasn't a big difference between the stage 1-3 versions(couple mph), not enough to justify modding a stage 1, incidentally the virage is 150 lbs heavier then the vegas, but the virage is way easier to drive and goes through rough water better
  13. #13
    Jun 2004
    port st. lucie, fl
    i would probably say(based upon my observations of the vegas/virage) that the virage is faster then the vegas, and probably due to higher hull efficiency, but they are both great boats
  14. #14
    Belgium
    I wonder why they never applied the stage 3 virage bottom mod to the HST
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  15. #15
    JUPITER, FLORIDA
    I would agree with you based upon the fact that the Virage hull would be faster than the Vegas because it's an air entrapment hull and will create lift at speed. I did some research on the weights of the boats based upon 1988/1989 model years. The Valero V = 750 lbs, the Valero YT Bowrider = 800 lbs, the Virage ZT = 925 lbs, and the Vegas XT = 875 lbs. Pound for pound, horse power for horse power, it seems as if the Valero YT would be the fastest due to it's lighter weight, air entrapment (similar to the Virage ZT) and smaller length/narrower beam. Has anyone out there rigged a Valero YT (or Valero YT Bowrider/Vasseret) with big power????
    Cobalt 263/VP 8.1L
    SeaRay F16 Jet boat
    SeaRay 17' Seville
