Results 1 to 15 of 19
    Yuma, AZ
    How to run my motor out of the water?
    The boat I just purchased has a 200hp Merc with a aftermarket performance lower end. The water pick up is on the bottom of the nose cone. So my question is how can I run the motor unless I have it in the water? I'd like to run it before I take it out just to be sure not to mention running it for tune ups and such....
    Thanks,
    JB
    Jun 2004
    Union,Washington
    Depending on whos nosecone it is, some have a flush adapter for them. Or you could make one.
    Bear 45/70
    Some people are like Slinkies ... Not really good for anything....but they still bring a smile to your face when you push them down a flight of stairs.
    The Bill of Rights gives me the power to NOT have to apologize for someone else's "gun phobia."
    May 2005
    Greenville, NC
    Bob's makes a little rubber thingy that hooks over those pickup holes. Cost like 10 bucks.
    Ló fasz racing
    Joe Horvath
    Yuma, AZ
    Thanks for the info guys but I'm new to outboards. Could you post a link or something so I can know what to look for?
    Thanks again,
    JB
    Jul 2002
    Calais, ME
    Here's one from land and sea.
    ------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
    "Life is short - Get there fast...MERCURY"
    Jul 2002
    Calais, ME
    Jul 2002
    Calais, ME
    Here's another one at the bottom of the page.
    http://www.imcomarine.com/pages/on-line.asp
    CRYSTAL RIVER, FLA
    flushin
    May wanna check with ex owner or dealer 1st, my 96 Mariner has factory built into lower pan on the rear. I got hose quick disconnect at Home Depot. If it's a BOBS www.bobsmachine.com Good Luch with your new boat.
    "Where is Lee Harvey Oswald, Now that we really need him?"
    Jul 2004
    Baton Rouge, La.
    Thumbs down flush fitting
    Not supposed to run the engine when you're running water through the flush fitting....it's for flushing the block only.
    Omnipotence - gotta get me some.
    Aug 2003
    Manhattan Beach, Ca.
    Rickracer has an adaptor that fits over the CLE type units. you can run the engine with this adaptor, it simply supplies water to the water pump itself and the water pump does the work. Rickracer advertizes on S & F. Capnzee
    Jul 2002
    Calais, ME
    Quote Originally Posted by Hydrasports205
    Are you talking about the one that hooks directly to the block? Because if it is the flusher that mounts to the LWP that your talking about how do you think the water is going to get through the water pump, go up the tube, all through the block and heads without running it?
  12. #12
    Jul 2004
    Baton Rouge, La.
    Lightbulb
    I was referring to the fitting that BW described that came standard on some of the 2.5 fishing motors (mine included). The fitting ran water directly into the block - bypassing the water pump etc. It's a no brainer if you're using a flush attached to the lower that it's got to go through the water pump. DUH!!!!!!!
  13. #13
    Aug 2003
    I think hydrosports 205 is talking about a flush fitting mounted above the water pump as in the block. If that is the case, you probably wouldn't want to try to run the engine while flushing. This could be the case in a "tight" area where noise is a problem but you would like to flush the top end without running the engine. You cannot get water past the water pump without running the engine when you are using the typical "muffs" or "sleeve" that fits over the water intake. This is a "noisy" situation and not possible in all parts of the country! Capnzee
  14. #14
    Nov 2001
    Buford, Georgia
    In a pinch I've trimmed my motor down into a wheelbarrow full of water with a hose running into the wheel barrow. With my motor height and angle of my driveway I was able to trim the motor level and still keep the pickups in good water. The hose keeps cool water in the wheelbarrow that would otherwise heat up as the spent water found its way back.
    It's not a permanent solution, but it'll get you out of a jam if you don't have a nose cone mask.
    --Brian Chandler--
    Sunshine Syndicate Wiseguy.
  15. #15
    Yuma, AZ
    Quote Originally Posted by vector mike
    I believe this is exactly what I am looking for...
    Thanks Vector Mike and thanks to everyone else for the help...
    JB
