Results 1 to 9 of 9
    Nov 2005
    poconos pa
    Impeller Chart..
    I found a chart on a web page (but lost it) that tells you how fast you will go roughly in a jet boat (weight of boat and other things play a factor). It listed horse power + impeller size + rpm = MPH. If anyone has this info can you please post it? thanks.
    ft worth tx
    just type in berkelt jet pumps in search engine and itrll link yu somewhere to it
    Feb 2006
    Here ya go - link to impeller chart
    Quote Originally Posted by apollo18
    Here is a link to the "official" Berkeley impeller chart:
    http://www.cpperformance.com/TechTips/impeller.htm
    Can't say I'm good for nothin' now.
    Feb 2006
    Speed Calculator Link
    Here is Jerry Liddell's (LVJetboy) Jet Boat Performance Calculator, free download, that will actually calculate MPH for your setup:
    liquidaddiction.net/pump.html
    I think Jer is somewhat of a jetboat genius.
    Northern ILL.
    Quote Originally Posted by El Prosecutor
    I think you will find the American Turbine chart a little more accurate.
    IMPELLER SELECTION CHART
    AT, TJ, SD-309, DOMINATOR,
    BERKELEY, ENERGIZER KITS
    H.P. 9.5 9.25 AA A B C
    150 2900 3050 3200 3600 3800 4050
    200 3200 3350 3500 4000 4200 4450
    250 3450 3600 3700 4300 4500 4800
    300 3800 3950 4050 4550 4800 5100
    350 4050 4200 4300 4750 5100 5350
    400 4250 4400 4500 5050 5300 5600
    450 4450 4600 4700 5250 5500 5850
    500 4650 4800 4950 5400 5700 6050
    550 4800 4950 5100 5550 5850 N/A
    *THESE RPM VALUES MAY VARY ACCORDING TO HOW YOUR BOAT ALLOWS THE PUMP TO LOAD
    HORSE POWER REQUIREMENTS ARE AT THE PUMP SHAFT
    AMERICAN TURBINE JET DRIVE IMPELLER SPECIFICATIONS
    IMPELLER SIZE LARGE DIAMETER SMALL DIAMETER MACHINED ANGLE
    9 1/2" 9-1/2" 8-1/4" 25 DEGREES
    9 1/4" 9-1/4" 8-1/4" 20 DEGREES
    AA 9-3/32" 7-13/16" 25 DEGREES
    A 9" 7-1/4" 30 DEGREES
    B 8-3/4" 6-3/4" 33-1/2 DEGREES
    C 8-1/2" 6-1/2" 33-1/2 DEGREES
    UMPBA 926 Gas Jet
    Merritt Island FL
    ok who has a link that works?
    Northern ILL.
    UMPBA 926 Gas Jet
    Aug 2009
    Okla.
    Here is another one
    OHBA Growth Trough Participation
    http://www.myspace.com/okmulgeehotboatassoc
    Mar 2010
    california
    Not certain how legible this is as photo , but this is Duanes "extended HP" chart , very accurate and a very good tool as well Tom
