Results 1 to 5 of 5
    Florida Keys
    exhaust exit port
    I have seen 2.4L motors with both small and large exhaust exit ports.. At least that is the best name I can think of right now.. My question is should I cut my small port block to make it a large port and what stock motors came with the large port?? I have attached a picture that I found here to show you what port I am talking about.. Also to mention that I am having my exhast chest cut down some but not porting it to the max.. It is just a 2.4L block and not worth spending a bunch of money on just want to built a bit stronger motor.
    Lee McCune
    TowBoat US Captain ,Mechanic ,and E-bay salesman
    MY Marine related sales on E-bay
    Join Towboat US here.. https://www.boatus-insurance.com/joinN.asp?WT10120W
    http://www.salvagemaster.com/
    Springfield,La.
    Cut the exits to match the adapter plate...The matching iz actually more important than the size...A stock 2.4 iz capible ov 7800 to 8000 rpm in stock form...sum will turn more, but they reely don't make HP over that...
    louisiana
    rexy, that looked like an old bridgeport. i would steer away from that and go with a fishing mota.
    speedy russian
    Florida Keys
    this is not a picture of my motor just a picture that I found that shows the exhaust ports that I am talking about.. My motor that I am building now is just a stock fishing motor..
    Lee McCune
    Springfield,La.
    I picked up on that Lee...But I stick to my guns...Juss match the ports...If U make them bigger, juss make sure the openings in your adaptior plate is the same size, all the way to the tuner...U don't want it to open up and then choke down before it gits to the tuner...Juss use your tuner az a guide...If U wanna open up the block, open it up to the size ov your tuner inlet!!!...JMO..REX
