Results 1 to 15 of 18
    Unhappy Where to set timing at idle for saftey margin on boat being sold?
    help! please
    how do i set the timing at idle on my omc? its got to be sold thurday and i havent a clue how to set timing
    THANKS ALOT BMAC!!
    Sep 2002
    PSL, Florida!
    you picture didn't let me zoom in enough. but the red arrow should be the idle timming stop the blue box should have the WOT stop in it. it will be on the trottle linkage arm.
    both idle and wot stops shop be on the air box. 2-6 degrees after TDC for idle 18 degrees BTDC for WOT.
    Don't lick my boat, It makes it sticky!
    Another Hitman for the Sunshine Syndicate!!
    2011 Seafox Viper
    Sep 2002
    PSL, Florida!
    helps if i post the pic im reffering to huh!!!
    2011 Seafox Viper
    Sep 2002
    PSL, Florida!
    scanners not working or i would scan the page. pictures came out fuzzy but here is the picture fromthe book. same arrows red for idle blue for WOT (wide open throttle)
    idle at 2-6 deg ATDC (after top dead center)
    WOT at 18 deg BTDC (before top dead center)
    2011 Seafox Viper
    May 2001
    Hickory NC
    5 Post(s)
    Jay you have them back wards. K is the idle timing. Red is WOT stop for timing, blue is throttle possition stop at idle.
    Sep 2002
    PSL, Florida!
    aparently it is to late for me to be giving advice...
    laker you absolutly correct...
    2011 Seafox Viper
    Apr 2002
    Dover DE
    thats the linkage for a V-8
    Sep 2002
    PSL, Florida!
    page says for V-6/V-8
    2011 Seafox Viper
    Apr 2002
    Dover DE
    Just messing Jay, I was looking at the diagram and say that looks strange. Just the linkage "M" is attached to is slightly different.
    May 2001
    Babylon FL off-grid
    Question OMC WOT timing
    I've heard that the OMC WOT timing must be set under load. Will it be OK for Kevin to set WOT timing without loading the motor and if not, where should he set the timing for a margin of saftey WITHOUT a load on the motor? He just wants to get the thing running and sold in a few days to an e-bayer.... Safe for the buyer and uncomplicated for Kevin?
    Thanks fellas......
    B.MAC
    Jesusfreak of the
    Sunshine Syndicate
    http://www.harvesthousejax.org
    Check out my cool Church family at: http://mybridgechurch.ning.com/
    Sep 2002
    PSL, Florida!
    charlie, "k" looks weird to me, on mine it looks like a bicycle tire pump handle.
    B. Mac, I've heard that too. but I've never seen it anywhere. and how does the linkage know the difference? I've always set mine by pulling all wires except number 1 and having some one stand on the gass pedal (or just lay the lever down to WOT) and crank it with a timing light on it. when i was in the CG i hung of that back of the boat at 50. im not doing that on any of these beasts!
    2011 Seafox Viper
  12. #12
    Re: OMC WOT timing
    Thanks fellas......
    B.MAC
    couldt have said it better my self
  13. #13
    Apr 2002
    Dover DE
    Tie the boat down on the trailer real good back it way down the ramp, run the motor and set it that way. Quick and easy. Make shure you warm the motor up enough to set the idle timing.
  14. #14
    Aug 2003
    Orange County, NY/ Schroon Lake, NY
    Man if that ain't a safety tip,,,,seen people drive em over the front w/ low pitch props Just cause they "sank it" too deep.
    Just in far enough to get water pressure
  15. #15
    Apr 2002
    Dover DE
    I sink them a little deeper to keep the prop from blowing out.
