Results 1 to 15 of 18
02-03-2004, 11:13 PM #1
02-03-2004, 11:45 PM #2
you picture didn't let me zoom in enough. but the red arrow should be the idle timming stop the blue box should have the WOT stop in it. it will be on the trottle linkage arm.
both idle and wot stops shop be on the air box. 2-6 degrees after TDC for idle 18 degrees BTDC for WOT.Don't lick my boat, It makes it sticky!
Another Hitman for the Sunshine Syndicate!!
2011 Seafox Viper
02-03-2004, 11:52 PM #3
helps if i post the pic im reffering to huh!!!
2011 Seafox Viper
02-03-2004, 11:59 PM #4
scanners not working or i would scan the page. pictures came out fuzzy but here is the picture fromthe book. same arrows red for idle blue for WOT (wide open throttle)
idle at 2-6 deg ATDC (after top dead center)
WOT at 18 deg BTDC (before top dead center)Don't lick my boat, It makes it sticky!
2011 Seafox Viper
02-04-2004, 12:11 AM #5
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,624
- 19
- 270
- 215
- 520
- 5 Post(s)
Jay you have them back wards. K is the idle timing. Red is WOT stop for timing, blue is throttle possition stop at idle.
02-04-2004, 12:23 AM #6
aparently it is to late for me to be giving advice...
laker you absolutly correct...Don't lick my boat, It makes it sticky!
2011 Seafox Viper
02-04-2004, 12:45 AM #7
thats the linkage for a V-8
02-04-2004, 12:56 AM #8
page says for V-6/V-8
2011 Seafox Viper
02-04-2004, 01:01 AM #9
Just messing Jay, I was looking at the diagram and say that looks strange. Just the linkage "M" is attached to is slightly different.
02-04-2004, 06:42 AM #10
OMC WOT timing
I've heard that the OMC WOT timing must be set under load. Will it be OK for Kevin to set WOT timing without loading the motor and if not, where should he set the timing for a margin of saftey WITHOUT a load on the motor? He just wants to get the thing running and sold in a few days to an e-bayer.... Safe for the buyer and uncomplicated for Kevin?
Thanks fellas......
B.MACJesusfreak of the
Sunshine Syndicate
http://www.harvesthousejax.org
Check out my cool Church family at: http://mybridgechurch.ning.com/
02-04-2004, 01:16 PM #11
charlie, "k" looks weird to me, on mine it looks like a bicycle tire pump handle.
B. Mac, I've heard that too. but I've never seen it anywhere. and how does the linkage know the difference? I've always set mine by pulling all wires except number 1 and having some one stand on the gass pedal (or just lay the lever down to WOT) and crank it with a timing light on it. when i was in the CG i hung of that back of the boat at 50. im not doing that on any of these beasts!Don't lick my boat, It makes it sticky!
2011 Seafox Viper
02-04-2004, 03:30 PM #12
Re: OMC WOT timing
Thanks fellas......
B.MAC
02-04-2004, 03:52 PM #13
Tie the boat down on the trailer real good back it way down the ramp, run the motor and set it that way. Quick and easy. Make shure you warm the motor up enough to set the idle timing.
02-04-2004, 07:39 PM #14Originally posted by Charlie M
Tie the boat down on the trailer real goodJust cause they "sank it" too deep.
Just in far enough to get water pressure
02-04-2004, 07:43 PM #15
I sink them a little deeper to keep the prop from blowing out.
