Results 31 to 45 of 46
  1. #31
    Aug 2009
    mpls,mn
    1981 camaro
    Carbs tore down yesterday.Pretty clean for sure.One acc pump dry and froze up,all 4 power valves are to big for a S/C .And now i can boost reference them now that they are apart.
    I have had this car now for 3 1/2 months and a lot has all ready been done now as of sharing this build.
    Power brake booster needs to be swapped from it's 11" to a 7" dual diaphram unit [its on order should have it soon.Tall valve covers hit it.
    A/C delete,and had to remove right inner fender well to remove the f-glass box and install the a/c delete box-it's done now.Still get to keep the heat system.
    all brakes were like new and work great.It had a 267 chevy v-8 115hp motor and t-350 trans i drove it home 30mi and drove very well.Very clean car with new rear quarters done rest is rust free thats why i bought it.
    Interior is very nice cond also and thats a BIG PLUS also.Factory tach and gages but add new ones to the now modified console for the 4 speed.
  2. Likes NICE PAIR liked this post
  3. #32
    Aug 2009
    mpls,mn
    1981 camaro
    Console mod,4 spd pedals are now in also
    Attached Thumbnails Attached Thumbnails camaro console gage pod 005.jpg   camaro console gage pod 006.jpg   camaro console gage pod 007.jpg   concole gages 005.jpg   concole gages 006.jpg
  4. Likes NICE PAIR liked this post
  5. #33
    Gotcha!
  6. #34
    Aug 2009
    mpls,mn
    1981 camaro
    ST-10 trans. Got the core with a BOP bell housing date 1975 600.00 tore it down and all gears were great but would not shift into 2nd 1-2 nd gear hub and syncro toast and reverse gear bad also..So called him and he actually gave me 350.00 back as he said it was good.So replaced 2-3 3-4 hub assy and reverse gear parts so now rebuild all done 90.00 total to me.
    Attached Thumbnails Attached Thumbnails camaro parts,tranny 004.jpg   camaro parts,tranny 005.jpg   camaro parts,tranny 006.jpg   camaro parts,tranny 009.jpg   camaro parts,tranny 010.jpg
  7. Likes NICE PAIR liked this post
  8. #35
    Aug 2009
    mpls,mn
    1981 camaro
    Core was a 1990 454 from c-30 truck still std bore with 4 bolt mains and a cast steel crank that was std also so no machine work was needed as it was all in spec.Good score for 700.00 But now as it s done and the trans i have more in the motor and trans then the whole car.
    Attached Thumbnails Attached Thumbnails oil panrockers 003.jpg   454 tear down 001.jpg   oil panrockers 006.jpg   oil panrockers 007.jpg   roller rockers 003.jpg
  9. Likes Frank Molé, NICE PAIR, Will hedrick liked this post
  10. #36
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    Cool
    Just saw these guys product on Texas Metal TV show , looks like exactly what I'm looking for ,,, Built drop in motor I don't have the time or talent to build something like this not to mention beat the bushes looking for somebody to build one .
    LS Crate Engines, LS Stroker Engines, LT Engines - Hot Rod Company
    most overnite successes usually take at least 10 years
    Certified turd polisher,
  11. #37
    Aug 2009
    mpls,mn
    I understand that bro.A nice crate lsx would be awesome but thats a lot of coin more then what i got into this motor.
  12. Likes Frank Molé liked this post
  13. #38
    Cool
    my mom wouldn't let me take shop class been stuck payin all my life , Thanks Mom
  14. Likes racervboat, Will hedrick, NICE PAIR liked this post
  15. #39
    Aug 2009
    mpls,mn
    1981 camaro
    bbc require a/c delete box,so had to do it.
    Attached Thumbnails Attached Thumbnails ac and fender well removal 003.jpg   ac and fender well removal 005.jpg   ac and fender well removal 006.jpg   sc fuel system 004.jpg
  16. Likes Will hedrick, NICE PAIR, Frank Molé liked this post
  17. #40
    Aug 2009
    mpls,mn
    1981 camaro
    Well if the 2 v pulley for p/s dont fit i found the cure.
    Attached Thumbnails Attached Thumbnails ass brackets done 002.jpg   ass brackets done 003.jpg
  18. Likes Frank Molé liked this post
  19. #41
    "Showoff"
  20. #42
    Aug 2009
    mpls,mn
    Quote Originally Posted by NICE PAIR View Post
    "Showoff"
    You no damn right,i show you mofo.
  21. Likes NICE PAIR liked this post
  22. #43
    Aug 2009
    mpls,mn
    1981 camaro
    Motor finally in.Master booster in to.Clutch,flywheel,bell housing in also.
    Hope the tranny gets in this weekend.
    Attached Thumbnails Attached Thumbnails motor in and more 006.jpg   motor in and more 008.jpg   motor in and more 009.jpg   motor in 001.jpg
  23. Likes NICE PAIR, Frank Molé liked this post
  24. #44
    Aug 2009
    mpls,mn
    1981 camaro
    Well tranny got in friday,shifter done saturday.Today brakes get blead.
    Attached Thumbnails Attached Thumbnails motor and tranny in 005.jpg   motor and tranny in 006.jpg   motor and tranny in 007.jpg
  25. Likes Frank Molé, NICE PAIR liked this post
  26. #45
    Aug 2009
    mpls,mn
    1981 camaro
    Also got the S/C just dropped in to make the throttle cable bracket and finish the carb linkage.P/S and alt now done also.
    Attached Thumbnails Attached Thumbnails shifter in 002.jpg   shifter in 003.jpg   shifter in 004.jpg   shifter in 005.jpg
  27. Likes Frank Molé, NICE PAIR liked this post
  1. Truck cap or no truck cap for hauling boat
    By aggiestckl in forum General Boating Discussion
    Last Post: 02-08-2015, 01:28 PM
  2. MEGA TRUCK "Monster Truck" Chevy Stroker
    By roosterds650 in forum Non-Marine Items
    Last Post: 04-10-2014, 04:37 PM
  3. New Truck
    By Swamp boy in forum The Scream And Fly Lounge
    Last Post: 06-18-2009, 06:53 AM
  4. Best GM truck to tow 10,000+lbs?
    By mxz in forum Tow Vehicles and Trailers
    Last Post: 04-18-2003, 12:31 PM
