Results 1 to 4 of 4
Thread: Looking for a head
Yesterday, 06:15 PM #1
Member
- Apr 2017
- Iowa
- 53
- 16
Looking for a head
I have a cracked head on a 1999 Honda BF115A and need a replacement. Does anybody know where I might try to find one? Thanks in advance!
Yesterday, 10:02 PM #2
I've seen a few of them, they were crack in the exhaust port into the water jacket near the valve guide. Is that where yours is leaking .. ??? (just curious)
I would try either :
Chris Carson on this site Chris Carson Marine Service and Supply | South Florida marine service & supply shop specializing in reed valves & re-manufacturing of outboard motor powerheads
or
New - Used Outboard Motor Parts - Marine Parts Outlet
Yesterday, 10:07 PM #3
Member
- Apr 2017
- Iowa
- 53
- 16
Yep, that is where it is cracked. I guess there is a part number that supercedes this one as there were many warranty replacements. They also suggest going to a cooler thermostat in the future so that the shock of cooler water is not as great.
I will contact them. Thanks!
Yesterday, 11:01 PM #4
Thanks for your response. I have some pretty intricate TIG welding equipment, and I couldn't fix the one I tried ...
Small kinked up area, just out of reach to get a reasonable shot at it. Carbon / salt water in the crack and no way to clean / weld the back side of the crack, just made it impossible to fix. And I don't say that very often.
I'm sure you priced a new one ...
Let me not get started ... good luck
2.5 gaskets head ,exhaust. Intake ,2.4 head
By eli in forum Misc. Parts and AccessoriesReplies: 5Last Post: 09-26-2020, 12:15 PM -
head gasket and cylinder head
By drtyTshrt in forum Technical DiscussionReplies: 1Last Post: 03-26-2017, 08:47 PM -
EARLY opti head, Low Compression head, Pro XS head on 3.0L
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 07-20-2016, 11:26 PM -
Head torque on 4cyl mercruiser 488 the one with the ford BB head
By baddjonny in forum Technical DiscussionReplies: 10Last Post: 07-15-2011, 11:02 AM -
OMC Tech: 2.7 head repair?? filling head gouges
By rebible in forum Technical DiscussionReplies: 3Last Post: 07-13-2008, 09:44 PM
