Results 1 to 15 of 20
    Oct 2025
    Jupiter, FL
    21 superboat transom to stringer tie in end caps
Name:	superboat tie bar connector.jpg
ID:	546423Hey all, have the standard looking connector from the stringers to the transom, the end cap that looks like a circle that screws into the bar....anywhere that sells them? Mine is snapped, thanks!!
    Heim joint
    Bearing shops have them
    Jun 2018
    Orlando
    That's a Heim Joint. standard part, just have to measure and find a replacement.
    https://www.mcmaster.com/products/ba...s/rod-ends-2~/
  4. Likes doug7488 liked this post
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    whaaaaat? you lost me , transom and stringer are bolt reinforced ? never saw such a thing , makes sence , I guess . could you get a better shot of the whole bracket ? thanks
    most overnite successes usually take at least 10 years
    Certified turd polisher,
    Quote Originally Posted by mr fun View Post
    rigid part in a semi rigid structure is not good engineering
  7. Thanks mr fun thanked for this post
    Oct 2025
    Jupiter, FL
    I have seen it a million times, just dont know where to buy one in west palm beach florida.
    Sail boat parts place would have one... Gonna be spensive..
    Feb 2021
    ne nc
    Summit racing, Jegs....
  11. Likes powerabout liked this post
    Quote Originally Posted by JKXLREIGHT View Post
    They have them in all popular sizes, both left and right handed thread.
    Right off of Blue Herron blvd.
    Chassis Engineering
  13. Likes XstreamVking, 108 liked this post
    Oct 2025
    Jupiter, FL
    thanks!!!
    we never needed anything like that at Sea Ray , not even when installing 92 series Detroits on foam filled stringers , seems like alot more stress on something that heavy while gyrating in offshore conditions . some areas you just don't skimp on ridgidity on layup
  16. #12
    N/A
    Common on Suberboat's. Those bars if i remember correctly should have play, and not be fully taut (perhaps why they broke); @radar would know.
    The 24 (and perhaps 21) does not have knees, my last 24' i optioned to have knees installed when transom was done.
    Attached Thumbnails Attached Thumbnails c638abc6-7dac-4328-9ccd-90c3bccf8bdd.jpg
  17. Likes XstreamVking, sonicss33 liked this post
  18. #13
    Oct 2025
    Jupiter, FL
    Yup very common on superboats...it wasnt over tightened, just old and finally busted, $5 fix!!!
  19. #14
    Oct 2025
    Jupiter, FL
    sea ray? with diesels....yea no this is an outboard, sea rays dont......need them. skimp on layup? ohhhh yes they are super high quality!
  20. #15
    you need good knees to run and jump
  1. Carbon Fiber Stringer/transom tabbing?
    By Check_Jo3 in forum General Boating Discussion
    Last Post: 02-01-2022, 12:43 PM
  2. Looking for feedback on my plan of attack to reglass my transom/stringer/floor
    By ADDvanced in forum Fiberglass and Composites Discussion
    Last Post: 07-25-2021, 10:27 PM
  3. Question: Resale value of boat with plywood vs foam transom/stringer?
    By ADDvanced in forum General Boating Discussion
    Last Post: 06-03-2021, 05:38 PM
  4. Transom to stringer tie bars
    By genob in forum Custom Rigging and Metal Fabrication
    Last Post: 02-24-2019, 01:52 PM
  5. transom and stringer in sections?
    By pcrussell50 in forum Fiberglass and Composites Discussion
    Last Post: 01-22-2010, 10:01 AM
