Results 31 to 43 of 43
Thread: 21Ft Skater Questions
10-18-2025, 03:13 PM #31
I like to keep it simple. The green line is neutral trim, parallel to bottom. The bottom of center arrow tab straight even with bottom. Up is up on both scales.
engines show trimmed way out as it sits on lift. Label on panel is opposite with current engine actuators.
With the tape I can simple look with no need to calculate or think numbers. Just were I am relative to neutral.Last edited by Jim Speros; 10-18-2025 at 03:15 PM.
Jim
10-18-2025, 05:51 PM #32
10-18-2025, 06:26 PM #33
She's a '94. 28 number 38 with 3 rd pair of engines. '22 300 R's
Jim
NICE PAIR thanked for this post
10-18-2025, 06:57 PM #34
And how does she run with a pair of Rs ?
10-18-2025, 10:13 PM #35
I am happy with the R's. Not a lick of trouble with them. After 3 seasons I still learning things about the boat and what its capable of. Still fine tuning my propeller selection.
Jim
10-19-2025, 08:27 AM #36
10-19-2025, 01:28 PM #37
10-19-2025, 02:02 PM #38
Jim Speros thanked for this post
motexas liked this post
10-19-2025, 03:06 PM #39
10-22-2025, 12:53 PM #40
Ran to add fuel this am with my 18 degree thru hubs. She lopes gently between 55 and 65. Carries nice and smooth and 70 and above.
I feel I need to mention I don't really care at what speed and how bad it lopes as I always go faster. If it lopes I simply just push the throttles forward and she smooths out.Jim
NICE PAIR liked this post
10-22-2025, 12:56 PM #41
I spend 95 % of the time trimmed neutral or half bubble in.
Jim
10-22-2025, 05:49 PM #42
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,956
- 599
- 100
- 520
- 631
hey jim. out today in the 18s running a drag 4 just a little more addeleration to get it flyin flat. it was choppy, motor was moving around too.much,must be air. planes off easy, jacked way up. still cant hold it w o t. cool , dry air here. what do you think about REMOVING some sand from the nose? adding hasnt done much good for the hop.
10-22-2025, 07:24 PM #43
If weigh in bow didn't help the hop Yes, remove some or all.
I think there are two scenarios to consider when balancing your boat.
How it runs and will it run best at neutral or slightly in and
How it flies when it leaves the water. Does it kite, stay reasonable level or tend to land bow first? I like it to fly reasonable level and I'm willing to compromise a little top speed for good manners.Jim
21ft skater, trick, or extreme
By Travism in forum Hulls WantedReplies: 0Last Post: 07-06-2020, 03:46 PM -
24 Skater questions
By Sea2jet in forum General Boating DiscussionReplies: 8Last Post: 11-21-2015, 02:59 PM -
Skater 28 Questions
By mikesufka in forum General Boating DiscussionReplies: 7Last Post: 09-03-2015, 08:08 AM -
21ft Skater
By PHISH in forum General Boating DiscussionReplies: 4Last Post: 01-23-2006, 04:54 PM -
21' Skater questions
By AlaskaStreamin in forum General Boating DiscussionReplies: 29Last Post: 02-04-2004, 08:04 AM
