Results 9,736 to 9,750 of 9754
Thread: Post your Favorite Memes Here
10-12-2025, 10:31 AM #9736
NICE PAIR thanked for this post
10-12-2025, 12:22 PM #9737
ai doesn't sound like it's sure!
Antennas can be located in various places depending on their type and purpose. For over-the-air (OTA) television reception, antennas are commonly placed on rooftops, in attics, or near windows to maximize signal strength. Higher placement generally improves reception, with rooftops and garages being ideal outdoor locations. If attic access is available and there is no radiant heat barrier or metal roof, installing an outdoor antenna in the attic is also a viable option. Indoor antennas are typically placed near windows or on top of the television set, ideally as high as possible and away from obstructions like metallic mesh or reflective coatings.
For vehicles, antennas may be hidden within the vehicle's structure; a common location is metallic traces on the rear window, just above or below the defroster lines. In mobile devices like smartphones and tablets, antennas are built-in and not visible, often integrated into the device's frame or circuit board.
In specialized applications, such as space communication, large antennas are located at ground stations, like the 70-meter antenna near Madrid, Spain, which can transmit and receive signals from deep space. For Wi-Fi and cellular networks, antennas are often embedded in routers, access points, or base stations.
The optimal placement of an antenna depends on the signal source, local terrain, and the presence of obstructions. Tools like online transmitter locators or apps such as Antenna Point can help determine the best direction and location for aiming an antenna toward broadcast towers.
AI-generated answer. Please verify critical facts.
Will hedrick thanked for this post
racervboat liked this post
10-12-2025, 03:35 PM #9738
5000 RPM
- Aug 2006
- virginia
- 844
- 45
- 151
- 544
- 1118
10-13-2025, 07:17 AM #9739
6000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,605
- 68
- 578
- 3879
- 5510
doug7488, racervboat, NICE PAIR, rock, CRH1, motexas, Dain, 89LASER, Frank Molé, Velocity72 and 3 others liked this post
10-14-2025, 08:00 PM #9740
6000 RPM
- Feb 2010
- Louisiana
- 1,712
- 523
- 745
- 2869
- 3154
10-15-2025, 10:49 AM #9741
10-15-2025, 11:33 AM #9742
Hey dude. We are not supposed to post nasty pics. Geez.
RockTeam Junk
10-15-2025, 11:58 AM #9743
10-15-2025, 11:58 AM #9744
10-15-2025, 03:45 PM #9745
10-18-2025, 08:45 AM #9746
10-18-2025, 10:39 AM #9747
10-19-2025, 08:01 PM #9748
10-23-2025, 02:30 PM #9749
6000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,605
- 68
- 578
- 3879
- 5510
10-23-2025, 02:30 PM #9750
6000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,605
- 68
- 578
- 3879
- 5510
Post your favorite pre-1990 boat..
By doc_texoma in forum General Boating DiscussionReplies: 82Last Post: 09-15-2017, 06:52 PM -
Post your favorite pic of your boat
By Viper GTs in forum General Boating DiscussionReplies: 309Last Post: 02-18-2012, 09:07 AM -
Post your favorite boat of 2008 Summer
By SnakeBit in forum General Boating DiscussionReplies: 36Last Post: 09-26-2008, 05:36 PM -
Post your favorite outboard photos
By sms in forum General Boating DiscussionReplies: 89Last Post: 03-22-2004, 11:05 PM
