Results 1 to 14 of 14
09-03-2025, 11:19 AM #1
Alpha SS/V6 outboard Gear case interchange
I have a brand new Alpha SS gearcase housing with the CLE and lowered pickups (just above the bullet at the nose). I would like to build up a spare 20" outboard lower unit with it. I am being told that the outboard internals will fit. Anyone done this or have some knowledge of it?
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
09-03-2025, 02:11 PM #2
Member
- Aug 2021
- Wisconsin
- 53
- 7
Those alpha SS drives are worth money and sought after
I think you would be doing yourself a disservice if it is possible to throw outboard internals into it..I would imagine it wouldn't be as cost effective as buying a standard unit
09-03-2025, 04:29 PM #3
Pm sent
1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
09-03-2025, 05:05 PM #4
09-03-2025, 05:19 PM #5
powerabout liked this post
09-04-2025, 08:58 PM #6
09-05-2025, 07:19 AM #7
Supporting Member
- Jul 2004
- Connecticut
- 6,248
- 516
- 201
- 1065
- 1113
Crazy to mess with a legit Alpha SS. Strong market for them.
09-05-2025, 11:37 AM #8
09-05-2025, 01:20 PM #9
09-08-2025, 09:26 AM #10
09-08-2025, 06:04 PM #11
No, I made an outboard unit out of it. Drilled and tapped the oil transfer hole 1/16 npt and put a pipe plug in it...so if the owner ever wanted to put it back to a sterndrive unit just take that plug out. I wanted as close to 1.5:1 as possible for that application, but you could put whatever ratio you want in there. However, if I remember correctly the front bearing diameter on the Alpha SS is smaller than the CLE (which is the same as sporty and big bearing fishing). It may have been the same diameter as the later model non ratcheting fishing gearcases. If thats the case then you'll have to get a non ratcheting 1.87 set and then put the alpha spool+crank shifter with the non ratcheting clutch. It is possible cause I did it, but it was a few years ago so I do not remember all the details.
09-08-2025, 06:50 PM #12
The Historic Photo Master
- Jan 2004
- Florida
- 38,479
- 75
- 1750
- 375
- 20213
- 4 Post(s)
...yeah, i was going to mention the oil transfer hole. it has/had an o-ring there, at the port, on the gearcase. i remember installing one of the very first run of those, with a 454 magnum (330 h.p.) alpha ss i/o package. think it was in 1986(?). took it out for the initial seatrial, speed test & magazine shoot. the drive froze up & we got towed in. merc rep came in, we broke the drive down & discovered merc forgot to machine the entire oil passage into the lower housing. sorry for the flashback...
09-08-2025, 07:29 PM #13
09-11-2025, 11:32 PM #14
Pm sent
Yamaha Outboard Lower Unit Gear case
By parkerkyb in forum Lower UnitsReplies: 0Last Post: 08-19-2016, 05:28 PM -
Mercury Tech: Coning an ALPHA case
By 89bullet in forum Technical DiscussionReplies: 10Last Post: 01-25-2014, 09:48 PM -
Mercury Tech: Will Alpha gears work in an outboard gear case?
By WATERWINGS in forum Technical DiscussionReplies: 13Last Post: 11-25-2010, 12:02 PM -
Propeller Question Alpha Case size to Stock 200 Case
By WOT RACING in forum Technical DiscussionReplies: 4Last Post: 07-08-2009, 08:05 PM -
3.0L gear case interchange
By topkick in forum Technical DiscussionReplies: 0Last Post: 05-20-2005, 10:40 AM
