Results 1 to 11 of 11
    May 2009
    7 Post(s)
    How often do you guys set your valve lash?
    My 2000 Mercaha (Yamaha F100 power head), had it done about 50 hours ago.
    I’m away from my manual at the moment so I don’t know what it says. Also wondering if it is typical to run the valves more frequently than the manual says anyway.
    -Peter
    "padded wonder"
    __________
    the wet:
    18’ Bahner bow rider, 2.4/200
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
    I have fishing guide buddies that never adj. their valves even after 1000 hrs. Usually ran em till they blew. One guy got nearly 3k hrs on a 115 yammi. Were yours noisy?
  3. Thanks pcrussell50 thanked for this post
    Likes pcrussell50 liked this post
    Pekin, IL
    Gonna take some time for me to get used to 4 stroke outboards. I thought this was a trick question or maybe just a joke.
    Rock
    Team Junk
  5. Thanks pcrussell50 thanked for this post
    Likes XstreamVking, David - WI, pcrussell50, 22R liked this post
    No need to get used to them, they're just a flash in the pan. Be gone soon.......hahahaaa. I wish! A new 400#, 400HP 2 smoke with a nice slick lower would be real sweet...
  7. Likes 22R, David - WI liked this post
    May 2009
    7 Post(s)
    Quote Originally Posted by rock View Post
    Rock
    It's the motor that came on the boat when I bought it. It's only a Whaler. Can barely do 40 with the wife and two girls and daytime lake gear.
Name:	Gray Whale at Lone Man isthmus 2025.jpeg
    It is fuel efficient I will say that. And super quiet at idle, though I don't know why everyone says four strokes are quiet because it's not at all quiet at cruise, just a different kind of sound than a two stroke.
    Anyway, maybe I won't be too wrapped around the axle over valve lash adjustment just yet. The mechanic that did the valves a hundred hours or so ago (maybe it was only 50 hours?) was impressive and trustworthy and the engine runs nicely.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    I can't see the reasoning behind adjustment or checking of the valves every 100 hrs. There's no reason I know for them to get out of adjustment under normal use. If someone knows why it would be needed let me in on the secret. As long as it runs nicely, let er eat.....
  10. Likes David - WI liked this post
  11. #7
    May 2009
    7 Post(s)
    Thanks, mate. I like this advice. We don't put 20 hours a year on this motor anyway.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
  12. #8
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    some people just cant help themselves
    most overnite successes usually take at least 10 years
    Certified turd polisher,
  13. #9
    Jan 2020
    Pittsburg, Ca
    1000 hr at the most frequent. I checked one at 4500 that had never been done before and it was still in spec. I have 1368 on my 2020 rn and I haven't checked it and I am not going to for a while. It is slightly different than yours in that it is roller-rocker overhead and yours is true overhead with buckets...but valve lash/wear is similar.
  14. Thanks pcrussell50 thanked for this post
  15. #10
    If you keep your oil and filter changed and keep the oil clean and undiluted then there will be very little wear going on. A long time ago I worked at a Honda dealer than sold a lot of motors to commercial crabbers and shrimpers. Of course they did not change the oil frequent enough. It was always jet black when it was finally changed and their valves would almost always need adjusting.
    1970 15' Allison/135 Chrysler stacker
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
  16. Thanks pcrussell50 thanked for this post
  17. #11
    Dec 2009
    middle tennessee
    In your application I wouldn't really worry about it.. If the valve lash is getting far enough out of spec to make any kind of difference in performance you have some kind of wear going on. Either valve, valve seat or camshaft wearing out most likely. In that case a valve adjustment isn't going to fix it, or will fix it for a few hours.. Because once that kind of wear starts it just keeps getting worse.. Fast.
  1. Replies: 2
    Last Post: 03-17-2016, 06:05 AM
  2. Casale toploader gear lash
    By Frankm246 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 07-08-2014, 11:35 PM
  3. Poppet valve/relief valve issues 1978 2.4l Merc
    By rujr in forum Technical Discussion
    Last Post: 06-24-2013, 08:21 PM
  4. adjustable 455 valve lash
    By boatermike in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-16-2010, 01:10 AM
  5. Dodge Cummins valve lash
    By Scott in MN in forum Tow Vehicles and Trailers
    Last Post: 11-24-2009, 07:20 PM
