Results 31 to 45 of 46
Thread: School me on OMC V8 Outboards
08-19-2025, 12:09 PM #31
08-19-2025, 12:19 PM #32
Instigator thanked for this post
NICE PAIR, sonicss33, Greg G, Rhinoortiz, Instigator, V pads, NoLimits, MattGreen, powerabout liked this post
08-19-2025, 05:45 PM #33
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,633
- 21
- 270
- 219
- 524
- 5 Post(s)
Most have no idea how much time is involved to port one of these engines. Sure you can do a quick clean up but a real port job takes a lot of time and effort. Building a 350 hp V8 is not bad but as power goes up the effort and time involved multiplies.
08-25-2025, 03:25 PM #34
Instigator liked this post
08-25-2025, 04:59 PM #35
5000 RPM
- Sep 2021
- New Richmond, Ohio
- 103
- 9
- 31
08-25-2025, 06:04 PM #36
No that's just cutting block open to grind aluminum and steel sleeve to make the intake ports larger, then welding it back together. back into block, I've never saw anyone do what he does, cutting the block open to get inside to do modifications. side area behind the ports wide open,
I really know very little of what he does in there, call him if you want to know. He has not built me anything in 20 some years, I run Mercury's
He is porting the block and new pistons of a 90 hp Yamaha 2 stroke for me over the winter, when he has nothing else to do
He stays busy during race season with big OMC's , He races a V-6 from the 90's and wins a lot.
There is a Gentleman on this board who took him a 130 V-4 Yamaha, He claims almost 200hp from that motor now
That little V 4 on a 13 Biel boat broke 101 MPH, with a BIG fellow driving.
https://youtu.be/vs13AmvP4hQWe have invented the world; WE see
08-26-2025, 07:32 PM #37
The Historic Photo Master
- Jan 2004
- Florida
- 38,842
- 78
- 1781
- 385
- 20565
- 5 Post(s)
08-26-2025, 10:06 PM #38
08-26-2025, 10:45 PM #39
6000 RPM
- Nov 2006
- 1,759
- 18
- 183
- 86
- 785
- 45 Post(s)
08-29-2025, 10:21 AM #40
Member
- Jun 2022
- Edgerton WI
- 30
- 16
I tried to push tube framed mids when I was working at Merc, no dice. The Verado/AMS mids are mostly castings, with a couple tubes welded on.
Anyway, dudes, this thread is AWESOME. I'm still researching every night and learning more and more. Let's keep this going.
First, I will call Monty at some point but I don't even know enough to ask the right questions. My current plan is to build my 3.6GT. Could I go Merc? Sure. But my boat was originally rigged with this engine, and now that I have one I'd love to hear it bark again. Also, a 22' deep V is kinda big for a 2.4/2.5 isn't it? I would think the torque of the v8s would be more appropriate on this style hull, and a smaller/rev happy merc would be happier on a shallow v/lake boat.
I'm still stripping my engine, but I've been reading about porting a lot on dirtbike and snowmobile forums, not so much information on outboard porting that I've found so far, and it's generally just beveling/rounding the edges of the ports on the sleeve. If anyone has links I am a sponge and spend at least an hour every night reading.
Right now I'm planning on getting the pistons out, then getting the sleeves bored as little as possible to clean them up, round the edges of the ports. Anything else I should be doing while I'm in there? Not looking to build an all out race motor, but while I'm in there I'd like to be aware of other mods.
My crank has some rust on the circular sealing disc things, but all the journals/bearing surfaces are perfect. Current thought is to build an electrolysis bath to remove the rust, as it's not destructive.
One other question re: gearcases. I have a 25" mid with normal looking gearcase. It looks like the 20" mids had an offshore exhaust snoot, and high speed gearcases. Is there a reason this wasn't offered on the 25" mids? And can a high speed gearcase be adapted to a 25" mid by swapping out the taller driveshaft? I've also seen some people running merc gearcases???
Keep it up dudes. And yeah gimmie those camshaft part numbers lmao
08-29-2025, 07:44 PM #41
- Jan 2004
- Florida
- 38,842
- 78
- 1781
- 385
- 20565
- 5 Post(s)
...wonder where all the 3.5 litre offshore v-8's are?...
09-03-2025, 10:59 PM #42
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,383
- 1082
- 421
- 4804
- 2207
- 9 Post(s)
2 of the gearboxes in Oz
10-04-2025, 08:08 AM #43
In kind of a catch 22 situation with finishing the shop.
A. Building funds are on vapors.
B. Can’t set up the shop until interior walls are skinned.
C. Can’t skin the walls until they’re insulated.
D. Can’t insulate until wiring is done.
E. Etcetera!
Good is, Fall is coming and is cooling off so I’m able to work in the barn until mid day before temps run me out.
W/no insulation/walls the barn is giant heat sink.
I put my temp gun on the roof when under direct sunlight and it was 118*!
So I had an epiphany!
So I can start to use the the shop and clear up some floor space, I built a workbench on wheels.
( can’t do much w/o my workbench!)
Not sure how many drywall screws I used but it was a ****ttt ton!I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
11-14-2025, 08:47 AM #44
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,633
- 21
- 270
- 219
- 524
- 5 Post(s)
If you port it like a dirt bike or snow mobile you will have an engine that does not work well on a boat. The power to weight and drag numbers do not favor the boat. Also rounding ports in the wrong area will kill power, port angles need to direct the flow to the proper area to make power and torque. When each port opens with regard to it's neighbor can also effect power band. An engine ported to push a light boat is not going to work well on a heavier boat. It also becomes a lot more difficult to get jetted correctly. IMO the best thing you could do is just a mild clean up
11-16-2025, 09:07 PM #45
5000 RPM
- Dec 2008
- San Diego, CA
- 267
- 10
- 27
How difficult was it to convert a V8 OMC to the newer Fastrac clamp bracket?
Old school hot rod outboards
By BVfast in forum General Boating DiscussionReplies: 117Last Post: 02-04-2021, 02:00 PM -
OMC Tech: School Me On Old School ('50's) 2 Banger JohnRudes......
By Instigator in forum Technical DiscussionReplies: 32Last Post: 01-14-2015, 07:48 AM -
Old School V.S. New School Paint
By EVILWAYS in forum General Boating DiscussionReplies: 138Last Post: 07-29-2009, 02:24 PM
