Results 31 to 45 of 46
Thread: 1998 FF build
  1. #31
    Jun 2018
    Floating around
    Are you going carb or efi? I’m currently running the four petal it’s good but my next build is going to be a seven petal. Efi both. Guess I’m going to find out the performance differences. My four petal pulls hard to 6000 rpm I can out accelerate most boats but it works hard for rpm after 6. I have managed 7500 before but I’m hoping the 7 petal opens things up after 6000.
  2. #32
    Dec 2009
    middle tennessee
    My 7 pedal Promax seems to pull strong to about 6800RPM before it seems to be past the HP peak... Doesn't really want to pull even a 26p very far past 7k... This is on an XB03
  3. Likes LakeFever, mercrazy liked this post
  4. #33
    TX......somewhere?
    if its still tha stock ECU thats all ya gonna get........... ya lucky ta get 7 grand.
  5. Likes skialot2 liked this post
  6. #34
    Jun 2018
    Floating around
    I’m running a chipped 225 promax ecu the limiter is set to 7600 iirc it might be 7800. In the cold air it pulls to 7 easy but in most day to day conditions it really falls off after 6. It still moves but it no longer pulls. I’m working on the new build and I want that thing to haul the mail to 7 with ease or better. I think it’s the four petal holding me back or maybe the stock canned fishing mid. Next motor is getting a smooth back too with a 260 tuner and the single plate. Pulling all the stops I can within reason at least. Met a guy who had a 370hp 2.5 build. Punched out block to 2.7 using custom sleeves. Ran 127 on a mirage. Crazy. I ain’t going that nuts
  7. Likes aj06bolt12r liked this post
  8. #35
    Dec 2009
    middle tennessee
    Its got a Brucatto. I set the limiter at 7500.
  9. #36
    TX......somewhere?
    sometimes tha brucatto isn't all its cracked up ta be.. they miss tha mark every once in awhile... ya might wanna get her ta check it... jmo
  10. #37
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by aj06bolt12r View Post
    How much tuning have you done with the fuel curve on the Brucato? Bucato cannot send out a tune that will hurt a motor. So if you are at sea level in FL or at 1250 feet of elevation at Lake Mead in AZ, Brucato sends you both the same curve. Its up to the customer to blow up their engine by playing with the settings or changing the curve with a computer. To me your RPM is maxed at the current fuel settings. or you need more compression.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  11. #38
    Dec 2009
    middle tennessee
    Compression is 140-145ish... Its probably still a little rich but I'm afraid to pull any more fuel. EGTs are into the 1200's at WOT as it is. I've tried slightly leaner and EGTs go up but top speed or RPM doesn't change. Piston crowns still look slightly rich to me but I'm not an expert at reading them and I'm not willing to do a true WOT plug chop because... Allison... Id love to tune it on a dyno.
  12. #39
    Apr 2023
    Long island, NY
    This is an EFI motor. Right now I only have a couple stock ECU's. an A8 and a A30 The A8 came with the motor and the A30 came from a 2001 2.5 200. But I am thinking about buying a Brucato and maybe a steamwheel.
    From what i hear, I have never done it, so it's just hearsay, if you really want these motors to rev up you need to raise the exhaust ports. It is supposed to shift the powerband higher and you can really wind them up. But you lose some low end torque.
  13. #40
    Jun 2018
    Floating around
    Post a pic of plugs #2+5. Better yet should start a fresh thread we be hijacking skialots build here
  14. Thanks skialot2 thanked for this post
    Likes aj06bolt12r, skialot2 liked this post
  15. #41
    Apr 2023
    Long island, NY
    I got my block back from Chris. It ended up needing 2 sleeves. Amazing how burnt up they were. Block looks great. He did warn me I had to redo the Marine Tex where I filled the oil injection casting.
ID:	545483 Click image for larger version.
ID:	545484 Click image for larger version.
ID:	545486 Click image for larger version.
ID:	545487Click image for larger version.
  16. #42
    Apr 2023
    Long island, NY
    I cleaned up my connecting rods with 320 grit ball hones following Jay Smiths technique. At first glance they look great. But if you hold them on just the right angle I can see some pitting on the surface. I can not feel anything with my fingernail. Not sure if this will matter or not. I only see it on the big ends of 3 rods. 3 rods are perfect. All 6 small ends are perfect too. I don't know if I should use these rods or if I should replace them?
ID:	545488 Click image for larger version.
ID:	545489 Click image for larger version.
  17. #43
    Jun 2018
    Floating around
    The block work looks fantastic! I’m not sure about those pits they might be okay but they might mar the needles slowly over time. Hard to say. While we are thinking rods here I am super cautious with checking rods for fit. Especially where the cracked cap meets you need to make 100% certain there is no lip or edge you can catch with your fingernails. The sides too this is importanr. I also check with feeler gauges over a mirror for flatness. My best looking rod was bent. I replaced two rods on my build. One was bent just a few thou over but too much for me and the other I could catch my finger on the cap just barely, again too much for me. Fortunately I have spares which I believe you have parts motors too so I’d be checking for cleaner rods because why not?
  18. Likes skialot2 liked this post
  19. #44
    Apr 2023
    Long island, NY
    This has pretty much been put on the back burner for now because I have been spending most of my time and energy prepping my Valero for re-core. It does not fit in my garage so I wont be able to work on it when it gets cold. But I did repair the burnt up Marine-Tex from the oil injection galley. I chiseled it all out and started over. This time with JB Weld. Pretty close. May need one more coat if I want to be nit picky.
  20. #45
    Jun 2018
    Floating around
    What was easier to work with the marine Tex or the job weld?
  1. Pre-build thread for a re-re-build of a Baja 190
    By curtis73 in forum General Boating Discussion
    Last Post: 12-23-2023, 07:15 PM
  2. Build my intruder back or build a black motor..advice needed!
    By Twilliams4003 in forum General Boating Discussion
    Last Post: 01-05-2021, 07:56 AM
  3. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  4. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  5. Replies: 7
    Last Post: 09-13-2003, 06:56 PM
