Results 46 to 60 of 104
06-23-2025, 07:27 AM #46
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
NICE PAIR liked this post
06-24-2025, 11:21 PM #47
06-25-2025, 11:33 PM #48
Back to the details.
Here is the water pump detail.
Because the 4 stroke has an oil sump in the leg, the water tube can't go up vertical.
The driveshaft goes through a tube in the sump but the water can't go that way, so it's piped out the side of the leg and upwards to the powerhead.
On this build, the pump in the lower unit will supply water for idle and slow going, but the main flow will come from transom scoops at speed.
This same system can be adapted to serve the 3.0L gearbox pump as well
06-27-2025, 03:09 AM #49
This job is moderately difficult.
Ambitious would be to plant a Ford Barra straight 6 on the leg.
The Barra is the Australian Ford 6, around 4.0L
Turbo north of 800hp.
06-27-2025, 06:56 AM #50
06-28-2025, 04:18 AM #51
No substitute for cubes.
2.0L might be a little light on torque, especially since this motor is probably destined for a 20fter.
07-10-2025, 09:10 PM #52
Here are some photos of work in progress.
The midsection is tacked down to a 40mm plate for welding.
All the welds are full penertration flux core.
I spent a couple of decades welding pipelines so this all comes easy.
The steel is 1/8 corten which makes the mid reasonably light.
The poor man's 15 inch mid is 1/4 inch.
The other photo is the gearbox plate, gearshift and water pump pipe.
The water pump will only be responsible for low speed water supply.
This plate system is what enables the mid to be fitted with either a 2.5 or 3.0L box.
The only significant differences between the two lower units is the bolt pattern and a small detail at the water pump fitting.
The centerline spacing of the forward dowel, forward bolt, shift shaft, driveshaft, water pump outlet, rear bolt and rear dowel are all the same between the 2 units.
Edit.
The 3.0L gearbox I've quoted is actually off a 4 stroke.
They are big solid boxes with 1.92 gears.
I don't have a 3.0L box yet.
Piad 1 dollar for the 4 stoke boxLast edited by NZ Sidewinder; 07-10-2025 at 09:46 PM.
07-11-2025, 03:18 PM #53
Supporting Member
- Jul 2004
- Connecticut
- 6,273
- 519
- 209
- 1077
- 1131
Paid 1 dollar........I love it! You have now officially gone beyond my range of understanding but I'm still watching this thread like a hawk. Thanks for sharing your work and btw I do know a clean and mean bead when I see one.
NZ Sidewinder thanked for this post
07-13-2025, 03:42 AM #54
A motor like this is destined for 100mph plus and there's no way I'm getting in the boat, or putting anyone else in it without a safety cell.
So in parallel with this job is the construction of a cell.
Cell building makes outboard building look like child's play.
There is some serious engineering going into this part of the job.
It involves mold making ( tooling), wet layup, vacuum infusion and wet vacuum bagging.
Also polycarbonate fabrication and canopy design and fab.
On a difficulty scale 1-10, it's 10.5
Today I mocked up the canopy in cardboard on the actual cell front half.
The back half is currently being fabricated on the mold.
It's a 4mm skin each side of 15mm foam.
07-17-2025, 12:46 AM #55
Here is the rear half of the cell seen the the previous post, getting it's foam core glued on.
The inside shell is still on the mold and covered in epoxy glue.
The pre shaped foam is placed on and vacuum bagged down.
The clamping forces obtained via vacuum are incredible.
In this case, the total weight of pressure is around 10 ton.Last edited by NZ Sidewinder; 07-18-2025 at 04:44 AM.
07-18-2025, 06:20 PM #56
07-19-2025, 02:22 AM #57
07-29-2025, 01:27 AM #58
I've been full time on the cell, so work on the motor is on hold for another week or two.
The cell is coming along.
Although today I visited my Merc parts guy and picked up 6 2.5 pistons on 141 rods, a set of rectangle 5 petal cages, a 2.5 bring block and a late model f block.
The late model f blocks are a nice block.
Another photo shows the screen cutting template and the male mold for rge cell roof.
Cell roofs are difficult because the rules say they need to be 4 inches above the drivers helmet.
This makes for a tall cell which is difficult to design.
The result is always contrary to racing linesLast edited by NZ Sidewinder; 07-30-2025 at 01:08 AM.
08-07-2025, 01:35 AM #59
I've been busy with the cell, but each day on the way out of my shed I grab the welder and do a bit.
Finished the welding today.
These photos show the mid with the 2.5 and 3L adapter plates.
The mid weighs 44lb and the adapter plate weighs 15lb.
Not light , but not too bad.
The mid is made of 1/8 corten.
It's lighter than the poor man's 15inch mid which is made from 1/4inch mild steel
08-07-2025, 04:09 AM #60
Great work all around.
Cant wait to see the motor mocked up!I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Photos: Mercury Racing 200 APX Four-Stroke Race Outboard Just Introduced!
By Scream And Fly in forum General Boating DiscussionReplies: 3Last Post: 04-21-2021, 05:45 PM -
96 780 Polaris two stroke in a home made aluminum boat. Cool Video
By LaveyT in forum The Scream And Fly LoungeReplies: 2Last Post: 03-02-2013, 10:16 AM -
fastest home made hull,s ever made ?
By afr in forum General Boating DiscussionReplies: 5Last Post: 04-25-2010, 09:50 AM -
Home made jet boat
By Powerplay25 in forum General Boating DiscussionReplies: 1Last Post: 02-20-2009, 12:34 PM -
Made it home with my boat
By Barefoot Bob in forum General Boating DiscussionReplies: 20Last Post: 12-21-2002, 07:53 PM
