Results 1 to 4 of 4
Thread: X Dimension
06-25-2025, 04:01 PM #1
Junior Member
- May 2020
- Alabama
- 19
X Dimension
26 Baja outlaw 700 HP Teague Platinum outdrive IMCO lower. No setback. Looking for recommendations on best X dimension from someone with experience with similar setup.
John S liked this post
06-30-2025, 07:05 PM #2
Junior Member
- May 2020
- Alabama
- 19
I may be complicating things, but I’m starting to consider some other options. A question I have is with regards to adding an extension box. My assumption is that a neutral box doesn’t change your ex dimension and so the only change that is possible would be to add a Shorty ifit looks like that will run better. However, if you add an extension box. it looks like that will run better. However, if you add an extension box that raises the X dimension you could use the standard lower but net a higher prop. The question I have is this is it better to run a neutral box and a Shorty or run a box that raises the next dimension and run a standard?
07-01-2025, 01:14 AM #3
call Bob at Teague marine , bet he could fill your head full in a very few minutes , and welcome to the sandbox
Fun Out
most overnite successes usually take at least 10 years
Certified turd polisher,
07-02-2025, 09:34 PM #4
The Historic Photo Master
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20603
- 5 Post(s)
...x-dimension is crankshaft centerline. do you know what your exsisting x-dimension is? do you know how to measure what your existing x-dimension is? i can tell you if you don't know how to measure it. does your gearcase have water intakes? if so, where exactly are they? do you also have a remote, transom water pickup? do you now have thru-transom exhaust? what steering do you now have, or are using?
X Dimension
By ChopperDr in forum Technical DiscussionReplies: 1Last Post: 06-30-2025, 07:06 PM -
A New Dimension
By j_martin in forum The Scream And Fly LoungeReplies: 1Last Post: 05-19-2009, 12:58 PM -
.462 Dimension
By SeaJay in forum Technical DiscussionReplies: 6Last Post: 06-11-2004, 07:06 PM -
Can someone help with a dimension?
By DaveR in forum General Boating DiscussionReplies: 4Last Post: 01-16-2003, 11:17 AM
