Results 1 to 11 of 11
Thread: just shuts off
    Feb 2011
    HUDSON, FLORIDA
    just shuts off
    out today after 30 min about 30 mph engine cut clean off. primer bulb full. starts right back up. on plane again 10 min. cut off clean again. did it three times, starts back up immediately. 2.4 efi. charging 13v. all dash 12v stays on, inj led stays on, no intermittent contacts. engine turns off clean. ??? no loose wires found.
    The electric EFI fuel pump? Bad key switch or kill switch?
    Feb 2011
    HUDSON, FLORIDA
    dont think its fuel because it starts back up with 1 crank, instantly
    TN
    Ecu connector
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by mercrazy View Post
    Ecu connector
    ill check that, hopefully thats it. thks.
    Feb 2006
    MN Land of 15,646 lakes
    Have seen this issue numerous times at the dealer level. Typically loose battery cables or the most likely is the 8 pin connector at the engine where the 8 pin control harness mates with/ connects to the 8 pin engine connector. Wiggle the 8 pin connector while running at idle, if it cuts out spread all 8 pins and test again. Good luck.
  7. Thanks KIRCHNER thanked for this post
    Likes sonicss33, David - WI, rock liked this post
    Baton Rouge, La
    I had a similar problem with a 260 and it was the ecu. I could restart and not even come off plane ! Changed the ecu and never had another problem
    Cheaters never Win !!!
  9. Likes David - WI liked this post
    Feb 2011
    HUDSON, FLORIDA
    i thought about trying that trick, going out right now. cleaned all plugs/cables+ have another brain i could try.
    Cudjoe Key FL
    Not any help for you but just wanted to say that you have the market cornered for bad luck. I read all of your threads and glad that you never give up.
    Feb 2011
    HUDSON, FLORIDA
    imcant help myself, thank you.its a gift but a curse also. what a day. motor fixed. my drag4 prop dissapointing,lots of slip 70 @7000, trophy 70@6000. skater18,2.4 220. both props 26p. boat too heavy for drag4,1200lbs 8'beam, im a old gearhead for sure..
  13. Likes sonicss33 liked this post
  14. #11
    Feb 2011
    HUDSON, FLORIDA
    Ecu connector
    i hit the ecu plugs with brake/clean. no more trouble today ran like a champ. great tip merc! my other rig 2.5 started doing the same thing;shut off twice!! bad 1/2moon control box plug for sure; just happen to have a new one..
  15. Likes tunnelmike liked this post
  1. 2.5 260 shuts off at WOT
    By ONE-A-DAY in forum Technical Discussion
    Last Post: 08-23-2017, 06:57 PM
  2. 260 shuts off at low rpm
    By blackcloud in forum Technical Discussion
    Last Post: 10-01-2013, 02:52 PM
  3. NJ Shuts Down Again
    By INXS in forum The Scream And Fly Lounge
    Last Post: 12-24-2008, 09:16 AM
  4. 2.5 just shuts off
    By Jeff "Yammer" in forum Technical Discussion
    Last Post: 06-24-2006, 02:02 PM
  5. 200 EFI shuts off
    By diskvalve in forum Technical Discussion
    Last Post: 05-25-2006, 08:26 PM
