Results 1 to 15 of 22
    Sep 2017
    ontario
    Who - Cut and weld yamaha 15 mid
    Anyone have a contact for cutting and welding a 90 yamaha mid / 20 inch to 15 .
    Thanks
    I did ask Cuda for Marty Powell a number but he is not responding .
    Mar 2024
    It will be a couple months due to busy but I'm building a jig table to do mids.
    PARADISE /Naples
    WHAT !
    Marty Powell 727 742 1235
    I dropped off my mid on Thursday
    461 Lakeside Place
    Largo Fl
    33771
    Just got back from Monty Racing
    Gordon has been in the same shop for 30 years, I believe.
    He's one of the GOOD old Boys
    BY the way, Marty has a can just like mine, 90 Yamaha already made,
    Said he did it many years ago, said the guy changed his mind, so you might save yourself a big buck if you could use it, I bet he'll sell it cheap, not doing him any good.
    Since your from Canada, the section he showed me is light,
    PS I don't see a PM from you ? about marty?
    Sep 2017
    ontario
    Sent Marty a text and a couple calls - no response
    PARADISE /Naples
    I know he has a cabin in NC ?
    Patience
    Sep 2017
    ontario
    Thanks helps to know - appreciate the effort
    Sep 2017
    ontario
    Sir I have had a conversation today - the mid you dropped off is a Yamaha 90 correct - just ensuring we are dealing with same application . I think mine is 90 odd model year - not sure if all the same but both mids he has are same .
    PARADISE /Naples
    Yes, 90HP 2004, Monty's boring 20 over and finger porting, going to 175 compression.
    The new boat is said to be 200 lb. bare hull. should move
    Sep 2017
    ontario
    Appreciate the reply .
    PARADISE /Naples
    Quote Originally Posted by kellytheaker View Post
    What boat are you putting yours on?
    Do they have any small boat racing in your area? if so, what classes?
    Sep 2017
    ontario
    New generation Voodoo from Spaeth Click image for larger version.
  12. #12
    Sep 2017
    ontario
    T850 and 750 but I am not involved . This will be a lake boat that is capable . Thanks for the help with the mid . I have been waiting to find a mid and I am not that educated on the rest of the process - - suspect shorten the water tube and shaft - Who is doing the shaft for you .
  13. #13
    Jul 2004
    Connecticut
    Ok we need several proper pictures of your Voodoo. That looks very interesting. Please post
  14. #14
    Sep 2017
    ontario
    I have not taken allot of pictures - the hull is currently being fitted for a cover . The hull is still the same Hydrostream voodoo 14 ft but a new cap was produced by Spaeth who produced several Hydrostreams over the years for Canada . Rear hatch is new as well as drop floor - lowering the seat area a few inches .
    Right now getting a mid is the reason for the post and a driveshaft shortened is the need since the new hull Transom is 15 inches vs the old at 20 inches .
    I will post up some pics when it’s back in the garage with a cover . Thanks for the interest .
  15. #15
    Sep 2017
    ontario
    Visually here is the differant cap vs the old - Click image for larger version.
  1. Weld on tab gone
    By outasite in forum Technical Discussion
    Last Post: 10-20-2012, 05:22 PM
  2. weld
    By mercrazy in forum Technical Discussion
    Last Post: 09-20-2012, 11:10 AM
  3. Why you should weld your LWP
    By Hottrucks in forum Technical Discussion
    Last Post: 05-28-2007, 08:38 AM
  4. Skeg: To weld or not to weld-
    By 1BadAction in forum Technical Discussion
    Last Post: 07-02-2004, 10:30 AM
  5. Has any one ever used JB Weld ??
    By Jeff "Yammer" in forum Technical Discussion
    Last Post: 08-21-2003, 04:28 AM
