Results 1 to 7 of 7
Thread: Bridgeport efi?
    TN
    Bridgeport efi?
    This thing is stupid rich.
    At 75F air temp, the sensor ohms at 10k. What should it read?
    Are these the same sensors as later model versions except these have longer leads and a plastic connector? If not, can I just use a resistor with the right value? What value should it be? Or can I just unplug it?
    What else would cause a rich condition?
    Mar 2004
    Brooklyn Park, MN
    go get a brucato and be done with it all. The old ECU with he TPS and all that is a PITA.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jan 2020
    Pittsburg, Ca
    The temp sensors are close enough to the new ones to work. I have put BP sensors in 260 motors and vise versa. Just make the leads right. Its 72 deg. right here now in the shade in the shop...a brand new sensor 13221T01 I just measured at 10kΩ and a used one I measured at 12kΩ
  4. Thanks mercrazy thanked for this post
    Jan 2020
    Pittsburg, Ca
    ECU, TPS or MAP sensor are probably your issue...not the temp sender.
  6. Thanks mercrazy thanked for this post
    Jul 2013
    Injectors not atomizing the fuel. Piss stream instead.
  8. Likes David - WI liked this post
    I live in Prineville Oregon which is in the central part of the state
    Get a Brucato ACU and you will neve look back. AMAZING how good that thing will run.
    CarterPowell
    TN
    Quote Originally Posted by Carter Powell View Post
    CarterPowell
    I put one on a 260 and lost 400rpm. It did idle good.
    Doesn’t matter now, I sold the Bridgeport. Thanks everyone.
  1. Wtb Bridgeport ecm
    By Cal 47 in forum Parts Wanted
    Last Post: 08-12-2015, 05:21 AM
  2. 2.4 bridgeport
    By wildwildwes in forum Technical Discussion
    Last Post: 10-28-2004, 06:59 PM
  3. 2.4 Bridgeport
    By Racemore in forum Technical Discussion
    Last Post: 07-15-2004, 06:41 PM
  4. bridgeport efi
    By YELLOWSS in forum Technical Discussion
    Last Post: 07-14-2004, 08:30 PM
