Results 1 to 11 of 11
    May 2006
    Edgerton, WI
    1993 Mercury 2.5 260 Cut
    -145 lbs compression
    -16A electronics
    -Brucato
    -Block work done by Mag in 2018 (see pitchers)
    -Hasn’t seen fuel since 2022
    -Located in Southern WI
    $4,900 OBO
ID:	539724Click image for larger version.
ID:	539725Click image for larger version.
ID:	539726Click image for larger version.
ID:	539727Click image for larger version.
ID:	539728 Click image for larger version.
    Hydrostream Owners Group
  2. Likes mirage511, Scream And Fly liked this post
    Sep 2021
    Buffalo, NY
    so this is a fishing block 175 cut to 260 specs?
    May 2006
    Edgerton, WI
    Quote Originally Posted by ctobias1984 View Post
    yes, I forgot to upload the build sheet from Mag Machine. Will update shortly.
  5. Likes mirage511 liked this post
    Arkansas
    If they did the work in 2018, how many hours and a compression check?
    May 2006
    Edgerton, WI
    Quote Originally Posted by Rick Pierce View Post
    I'd be surprised if there are 40 hours on it since rebuild from previous owner history; 145 lbs compression checked prior to posting. Only been one owner between the owner that had Mag do all the work and he spent most of his time battling typical HydroStream issues when the motor was rigged.
    also...price update.
    May 2006
    Edgerton, WI
    Quote Originally Posted by josh7_78 View Post
    Can bring to Suwannee in a couple weeks
    Great deal. I'm sure somebody at the Suwannee will definitely want that!
  10. Likes josh7_78 liked this post
    Dec 2019
    Spring Lake MI
    How many hours do these type of builds generally last between freshens?
    TJ @ Baker Engineering
    Tuff 24 300xs
    Tuff 16 90 Yammie
    3.75@199mph with LSX power!!!
    Jun 2018
    Floating around
    I spoke with Jay Smith about longevity and he said one of these iron lined warmed up 2.5’s that doesn’t spin too high will last 500 hours between rebuilds. Too high was 8k plus
  13. Likes josh7_78, skialot2 liked this post
    May 2006
    Edgerton, WI
    Price update.
    May 2006
    Edgerton, WI
    SOLD thanks S&F
  1. 1993 Mercury 2.5, 200 XRi
    By Blue Stream in forum Outboard Engines
    Last Post: 03-09-2025, 11:47 PM
  2. 1993 laser 388le boat and 1993 mercury 2.5l efi 280 offshore
    By Trikmit in forum General Boating Discussion
    Last Post: 02-28-2017, 07:44 AM
  3. 1993 Mercury 245 H.P.
    By MARBLEMAN2014 in forum Outboard Engines
    Last Post: 05-04-2015, 12:33 PM
