Results 61 to 72 of 72
06-29-2020, 09:51 PM #61
Screaming And Flying!
- Dec 2001
- 9,501
- 271
- 191
- 1979
06-29-2020, 10:27 PM #62
- Dec 2001
- 9,501
- 271
- 191
- 1979
And just forrr giggles ….I can lift/cary the ssm… need 2 hands for the T4 justa old guyhibn??
07-01-2020, 08:36 PM #63
The Historic Photo Master
- Jan 2004
- Florida
- 38,851
- 78
- 1787
- 385
- 20587
- 5 Post(s)
joyrider liked this post
07-01-2020, 08:45 PM #64
- Dec 2001
- 9,501
- 271
- 191
- 1979
Thanks Fujmo
io master Darn old eyes ……..
07-02-2020, 07:10 PM #65
Yamato and Eldredge both used CLE in the '50's
07-02-2020, 10:53 PM #66
- Dec 2001
- 9,501
- 271
- 191
- 1979
Thanks Sam.....and for thouse that don't howyhyyy,,,,explane,,,,
03-07-2021, 05:30 PM #67
8000 RPM
- Oct 2011
- Southern California
- 3,918
- 200
- 574
- 3541
- 2679
- 31 Post(s)
setting up a Number Six.
The elder statesmen and acknowledged guru of the performance sterndrive, John Klumpjan started in 1968 with Carl Kiekhaefer and his company Kiekhaefer Aeromarine.
He was assigned to assist engineer Larry Lohse, who would be instrumental in developing the first Speedmaster drive (the Speedmaster III). As the company introduced the Speedmaster IV and V, more race teams were using them and they only wanted one guy to rebuild them when that time came — that guy was Klumpjan.
“I have 16 world championships and eight of those were with Aeromarine,” said Klumpjan who is now 70 years old. Among the teams/owners that demanded that Klumpjan rebuild their drives were Jerry Jacoby of Ajac Hawk fame, Dr. Bob Magoon, Tom Gentry, Don Johnson, Bob Saccenti, Craig Barrie, Bernie Little and Renato Della Valle, whom Klumpjan referred to as “The Italian Donald Trump.”
“The key to doing an outdrive right, whether if it’s a 6 or an 8, is setting the gears to the horsepower and torque,” said Klumpjan. “It’s more important than ever because of the horsepower being created.” He believes that the Dry Sump Six is actually easier to work on than the Speemaster III, IV or V because of the immense size of all the components.
The most critical part of the rebuild in his eyes is properly loading the spur and helical gears before making the final settings. He does disagree with some of his colleagues that the upper gearsets are often the first to go in a Number Six. “The only reason it would go is if something plugged the oil from getting to the upper,” he said.
He said that the most important thing owners can do to extend a Number Six drive’s life is to keep up with oil changes. After the first 25 hours, or break-in, oil should be changed every 50 hours.
PRA publication
John K.
03-07-2021, 05:36 PM #68
8000 RPM
- Oct 2011
- 3,918
- 200
- 574
- 3541
- 2679
- 31 Post(s)
“Everybody wanted to build engines or do electrical or rigging,” said Matt Gilvey. “Nobody wanted to do sterndrives because they were afraid of them. People don’t understand setting up backlash or bearing preload.”
Gilvey teamed with Klumpjan at Doller Marine in 1988. From the start, he worked on Speedmaster III and IV drives. “The Number Six came out around 1990 and Gilvey received the Mercury Marine Master Technician Award in 1993.
Gilvey said that upper gearsets take the most abuse, depending on how hard owners are on their equipment. Like his compatriots, he said that the biggest concern he has when he rebuilds a Number Six is setting the load on the two spur gears. These are the gears that sit atop the two vertical shafts in the gear case. If you don’t get the load evenly balanced between the two, the engine’s power won’t be distributed evenly. This can shorten drive life.
Brian Jackson (former student of John Klumpjan) said that in addition to setting the load on the spur gears correctly, the pinion height and the shimming of the gears become critical when engines are putting out 1,500 hp. He said that the biggest factors in determining how often drives need to built are the power running through them and how hard the operator is on the equipment.
PRA publication.
powerabout thanked for this post
03-07-2021, 10:06 PM #69
- Dec 2001
- 9,501
- 271
- 191
- 1979
I wish someone was around when I was a kid putting them together as I had no instructions.......
Just the small ones........when we wanted to shorten the DS......I now have the manual for the I/Os and how to set the perload .....looks like a tough job.
02-26-2025, 09:50 PM #70
- Jan 2004
- Florida
- 38,851
- 78
- 1787
- 385
- 20587
- 5 Post(s)
11-09-2025, 06:34 AM #71
Junior Member
- Oct 2025
- Downingtown, PA
- 17
- 12
11-09-2025, 06:10 PM #72
- Jan 2004
- Florida
- 38,851
- 78
- 1787
- 385
- 20587
- 5 Post(s)
...have you talked to someone at hi-perf, i mean mercury racing, about your specific parts you need?...
