Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: FF block?
    TX......somewhere?
    Quote Originally Posted by JCSmile View Post
    The 2.5 245 was usually called a "2.5 carb". The parts manual would likely include other hipo parts like 16a flywheel, hipo exhaust divider, lightweight cowl, etc
    this.... tha nic motor......... tha '91 200 is a seven petal "production" both carb and efi... was tha only 7 petal 2.5 production motor built.
  2. #17
    Apr 2023
    Long island, NY
    Yes. It does have all that. It has the lightweight cowl. 16A flywheel. One piece adaptor plate. Single piston trim. Available shorty offshore midsection. Available CLE gearcase. It's got all the good stuff.
  3. #18
    Jun 2018
    Floating around
    I wonder what the 245 carb dynoed vs the 260?
  4. #19
    Jul 2004
    houston,tx
    91 was when merc released the production 2.5
    91 going into early 92 merc used 7 pedal fronts on the production 200 motors
    carb,,,efi,,,modvp and the 245 which was a 260 powerhead running on carbs instead of efi
    and lots of mismatched parts from the 2.4 to use up stock,,,
    most of 91 200s had the narrow 2.4 bottom guided rods and 2.4 crank
    by mid 92 went to the 2.5 rod and the shouldered 2.5 top guided crank
    so didnt know what was inside till pulled apart,,,,lol
    as far as 245 vrsing 260
    my findings as never dynoed things back in them days '
    the 260 had more initial punch with the efi
    but at 8k + ran the same,,,,and no rev limiter on the carb could pull higher rpms
    but i also chunked the whm carbs for the bigger wh20s
    so lil less on hit lil more over 8k in my opinion as no rev limiter to stop it
  5. Thanks David - WI, LakeFever, skialot2, Baker343 thanked for this post
    Likes David - WI, LakeFever, skialot2, Baker343 liked this post
  1. Replies: 3
    Last Post: 02-11-2019, 09:52 AM
  2. Replies: 2
    Last Post: 03-11-2016, 08:07 PM
  3. Replies: 5
    Last Post: 08-10-2015, 04:25 PM
