Results 1 to 7 of 7
    Oct 2017
    Jackson Ga
    Need some prop help!
    I have a Triton 186. It’s only rated for a 150. I just put a 200 FF 2.5 on it. Having trouble finding a prop that won’t run too many RPMs. Currently running a 27 tempest with my jack plate more than half way down and turning it 6000-6100. I knew I’d be fighting props putting a motor that big on my little bass boat.. but I didnt Think it would be this bad. Lol
    29p tempest will hold r's better, but it might kill the bottom end. That ff will turn 6500 easy...Stay with the 27 and enjoy the good hole shot.
  3. Likes OnPad, David liked this post
    Oct 2017
    Jackson Ga
    So it won’t hurt to run it 6200-6300?? I’ve been scared to. Lol
  5. Likes OnPad liked this post
    Nov 2021
    Northwest
    I will second what Xstream said about rpm. I run mine up over 6500.
    What you might try, is swapping the grey wire from the voltage regulator to the other regulator. Just to make sure you're getting a accurate measurement, and dont have a bad regulator. Rpm reading seems a bit high for that setup.
  7. Likes Coon Krazy liked this post
    Oct 2017
    Jackson Ga
    Quote Originally Posted by OnPad View Post
    What you might try, is swapping the grey wire from the voltage regulator to the other regulator. Just to make sure you're getting an accurate measurement, and dont have a bad regulator. Rpm reading seems a bit high for that setup.
    I was thinking the same thing. I dont have a regulator. I have A rectifier. But I’ll try that. My boat weighs 1350. I wouldnt Think that 27 would run that many rpms.
    Jun 2018
    Floating around
    Delete the oil injection and the black boxes. Set the timing to 23 and premix 40:1 and spin the thing as high as it will go. I spin mine to 7500 no issues
  10. Likes OnPad liked this post
  11. #7
    Nov 2021
    Northwest
    Quote Originally Posted by Coon Krazy View Post
    Sounds like a hot rod!
    If you can get it set up just right, it'll hurt some feelings of the fellers with modern 250hp boats.
    20 years ago, I co-angled out of a tr20. That ride was the fastest in our club, and very memorable. It was the catalist to learn everything I could in order to go faster.
  1. Replies: 1
    Last Post: 07-09-2023, 05:50 PM
  2. F1 / F2 Racing Items for Sale!! Dewald props, Performance Prop, Prop test wheel...
    By Spectre Powerboats in forum Misc. Parts and Accessories
    Last Post: 02-20-2018, 03:01 PM
  3. Replies: 1
    Last Post: 02-03-2018, 02:08 PM
  4. OMC Tech: Help! 225 carbed Johnson melting prop hubs / high exaust temps through prop hub
    By Tunnelvision1995 in forum Technical Discussion
    Last Post: 09-12-2017, 08:03 PM
