Results 1 to 15 of 17
Thread: Quiet
    TN
    Quiet
    I have several 2.5 midsections with cans removed and the 5 factory holes drilled to relieve exhaust/make more noise. I’m old and want a quieter engine. Does anyone have an easy way to block these holes? I don’t have cans to put back in.
    For $10 I would try something like this, not sure if they will blow out or not but it would take about a minute to find out. (Snap in from the outside.)
    https://www.ebay.com/itm/26551828957...64038e28b19768
  3. Thanks mercrazy thanked for this post
    I can't remember... are they 5/8" holes?
    Miami,Fl
    They make a plumbing plug that has a wing nut on one size and tappered rubber disk on other side that fits in the hole or pipe and you tighten the wing nut and it seals. Got mine at home depot.
  6. Thanks mercrazy thanked for this post
    Likes David - WI liked this post
    ...earplugs?......
    I live in Prineville Oregon which is in the central part of the state
    Those little snap in plugs come in many sizes, you need the half inch size. If you want to go cheaper they come in plastic and won't melt. Put a little JB weld on them or a little black silicone seal and you are done. I have done that to one of my motors.
    Carter Powell
  9. Thanks mercrazy thanked for this post
    These would probably even stay if you put them in the hole and pry them in tight with a wrecking bar?
    https://www.indigoinstruments.com/la...d-size-00.html
    The great corn desert of Iowa
    I used plugs similar to these to shut off the upper water inlet holes on a v-4 lower unit. Tap the hole, screw them in. https://www.autozone.com/gaskets-and..._0_0?rrec=true
    1971 Sidewinder 14 SS w Johnson 90 v-4
    1959 Texas Maid Falcon w Mercury Mark 35A
    1981 Sylvan Sportster w Johnson 85 v-4
    2006 Harris pontoon with a Yamaha 90
    1969 Sunfish sailboat
    Quote Originally Posted by Turtleherder View Post
    These holes are not really accessible... down by the cavitations plate.
  13. Thanks KIRCHNER thanked for this post
    TX......somewhere?
    bite tha bullet n find a used can ta put back inside... lotta harmonics and vibration goin' on with that part... those "patches" usually end up being a PIA...... jmo.
  15. Thanks mercrazy thanked for this post
  16. #11
    Jun 2009
    Bristol, Connecticut
    Ya let me know if u want to sell the exhaust housings...i like the noise...for now
    Feb 2011
    HUDSON, FLORIDA
    i have 1 you can have it, come n get it,mariner gray.
  18. #13
    TX......somewhere?
    tha can is just a liner that goes inside tha down housing.... all he really needs..
  19. Likes David - WI liked this post
  20. #14
    Feb 2011
    HUDSON, FLORIDA
    defective helm?
    after bleeding, 10 different ways, uflex sent me a new one. i bleed this one, no air, used the closed loop method, 30+ turns left then right, no air un the lines. still no good, wheel now acts like a rachet, have 1/4 turn of play,makes clunking sounds,thumping,banging, im no beginner at this, have two other rigs, one seastr,0ne seastr pro, im ready to ask for a complete refund which wont come easy for sure. not gonna get burned for 650$. i have 1/4 turn of play,with no drag at aPll. its a uflex33fm 2.0 brand new. WHAT is going on??? anybody??
  21. #15
    Jan 2020
    Pittsburg, Ca
    I have a liner I just threw in the scrapper you could have. May have others too. Let me know if you want one...but it may not even be worth what they want to ship big packages like that now. Up to you.
  22. Likes David - WI liked this post
  1. quiet pro xb 250?
    By VELOCITY 3.6GT in forum Technical Discussion
    Last Post: 05-27-2009, 03:12 PM
  2. Nice and quiet
    By flabum1017 in forum General Boating Discussion
    Last Post: 03-09-2008, 07:28 PM
  3. Awful Quiet Around Here
    By BathTubBabe in forum General Boating Discussion
    Last Post: 08-03-2002, 10:59 PM
