Results 1 to 15 of 15
    May 2014
    Australia
    WANTED Chrysler racing outboard
    Wanted Chrysler racing outboard ( Stacker)
    Complete outboard or parts
  2. Likes 108, ctobias1984 liked this post
    Celina, Ohio
    Not sure if this is still available but I saw it a while back on FB Marketplace. https://www.facebook.com/marketplace...60533665537359
    Mar 2023
    Elephant Butte, NM
    Saw this ad on Chrysler Marine group on F/B:
    "Hey to all Chrysler fans, Happy Thanksgiving !I have two NOS, racing lower units, Chryslers version of the SpeedMaster, along with one exhaust tower, mid section, and two props.
    In addition an NOS racing lower unit housing, empty, and one of the chrome stack extensions.
    Anyone interested ? E-MAIL [email protected] for photo's.
    Thanks and Happy Holiday's"
    May 2014
    Australia
    send some photo,s and details please and your location
    [email protected]
    Mar 2023
    Elephant Butte, NM
    Quote Originally Posted by gem56 View Post
    [email protected]
    Not mine, saw ad on face book. Has email in the ad.
    Jun 2012
    Indiana
    I have a 150 stacker I would sell. It has the speedmaster lower but is missing the nose cone. Otherwise, complete. Not running but turns over by hand.
    May 2014
    Australia
    chrysler stacker
    Quote Originally Posted by capteliminator View Post
    Thanks , please send some photo,s and your location
    Russell
  9. #8
    Jun 2012
    Indiana
    I'm in Evansville Indiana. I'll dig it out and take some pics.
  10. #9
    Jun 2012
    Indiana
ID:	538690Click image for larger version.
  11. Likes V pads, ctobias1984, Instigator, 108 liked this post
    Sep 2021
    Buffalo, NY
    Thats really cool, whats the hp on something like that? Rpms?
    Jun 2012
    Indiana
    I have never ran mine. It is rated at 150 hp. Not sure on redline either.
  14. #12
    Square head, top flat surface of the block and on the flat side surface of the head you'll find a 3 digit stamped code.
    On the block behind the coil #1 you'll find a year casting.
    Blocks and assemblies can get switched around over the years, more behind the stacks too and not just a bolt on if blocks swapped.
    150 started out 96ci 3.3125"x2.8 then also had a 100c.i. 3.375"x2 8"
    Should be a studded head , oring deck if original 96ci but the square head was '75 release and likely a big bore.
    Correct tested, not oiled up, carbs wide open PSI should be 185-195. If the grouping isn't real tight, pull the transfer covers and tension check the rings through the transfer ports with in out pressure, they must follow. Top rings breaking can show a decent psi if recent.
    It'll have true high ring pressure backed pistons .
    Jets should be 106 range but that can be changed, carbs will have casting date on the portside.
  15. #13
    So the square flat cylinder head was on the 150?
    1970 15' Allison/135 Chrysler stacker
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
  16. #14
    Last year 150 is '75/76. By then the previous design head wether small or big bore was not used. But.. maybe some carried over by availability.
    Like I said, stamped codes on both block and head will possibly id it.
    It could be a 135 head cut tighter or a non stamp cut tighter to yield the 195psi with the ex height.
    If it's the previous style the strike pad below #4 has the stamp, ex 372.
    The 150 years '71/72-76 had two styles of head possible wether small or big bore.
    It's easy enough to determine what the powerhead is with the head removed and a view of the top rings and ports and other details.
    Measured stroke to rule out a later crank swap or different powerhead too.
    If you were to id it with the cowl style and trim , that latch ended earlier in '73 , but did they continue it on the stackers?
    A closer look it the setup is needed.
    At some point a' 76 96ci 105 might have been dropped on it with the stacker trim and TC carbs, things happen over 50yrs.
  17. Likes Mark Poole ModVP liked this post
  18. #15
    Good info. Thanks!
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
  1. Chrysler Racing Outboard
    By gem56 in forum Outboard Engines
    Last Post: 02-10-2023, 11:29 PM
  2. New Chrysler/Force Outboard Factory Racing Complete Lower Unit
    By faztbullet in forum Ebay Listings and Other Internet Listings
    Last Post: 12-01-2017, 06:55 AM
  3. Wanted Chrysler Racing stacker outboard stacks
    By 1 off gn in forum Parts Wanted
    Last Post: 02-05-2017, 08:04 PM
  4. Replies: 28
    Last Post: 11-23-2015, 07:37 AM
  5. WANTED---Quincy Looper Outboard Racing Engines
    By Jeff Lytle in forum Outboard and Racing History
    Last Post: 05-31-2008, 11:12 AM
