Results 1 to 10 of 10
Thread: Smartcraft
    Nov 2005
    NE Alabama - Weiss Lake
    Smartcraft
    The water pressure gauge won't work. I've tried 2 different gauges. The gauge before and after theWP gauge in the daisy chain work just fine. Any ideas?
    TJ309
    Older 17 foot Laser / 150 Merc
    1993 Speedster 13 / 2019 Merc 60 play boat
    2020 Lowe 24' Pontoon boat / 250hp Merc. 51mph!
    72 Hydrodyne bubbledeck undergoing keel up restoration
    2 Jetski's
    Dec 2009
    middle tennessee
    Has it ever worked? Did you OHM out the sender?
    Don't you have to "configure" those CANBUS gauges so they all match the "starboard" (or "port") setting on the motor?
    Nov 2005
    Quote Originally Posted by aj06bolt12r View Post
    Neither gauge ever worked. All the rest work just fine. I did not check the sender, any idea where it is on a 150 4 stroke?
    TJ309
    2 Jetski's
    Jan 2020
    Pittsburg, Ca
    Quote Originally Posted by tj309 View Post
    Probably does not have a water pressure sender installed. 150 4s don't come with them, you have to buy separately and install yourself. There is a pigtail in the main engine harness for it, but its just capped off.
    Nov 2005
    Thanks! Where is the pigtail located?
    TJ309
    2 Jetski's
    Jan 2020
    Pittsburg, Ca
    Exhaust manifold area. Right where the sensor goes
    Nov 2005
    Right under the alternator?
    TJ309
    2 Jetski's
    Jan 2020
    Pittsburg, Ca
    Yes
    Nov 2005
    Thanks, I found the pigtail and the plug where the sensor goes.
    TJ309
    2 Jetski's
  11. Likes 25two.stroke liked this post
  1. smartcraft
    By mercrazy in forum Technical Discussion
    Last Post: 02-24-2021, 08:04 PM
  2. Smartcraft help?
    By aaronmt73 in forum Electronics, Audio Systems, and Wiring
    Last Post: 03-25-2013, 07:23 PM
  3. smartcraft
    By hotpony891 in forum Technical Discussion
    Last Post: 09-01-2011, 03:55 PM
  4. HELP ME! Smartcraft????????????????
    By Bullet Basser in forum Technical Discussion
    Last Post: 11-06-2006, 10:16 PM
  5. Smartcraft Help
    By seacow in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 05-21-2005, 08:03 AM
