Results 1 to 2 of 2
    Mar 2023
    SW Florida
    hull-core repair. make sure you don't have bunk dents before adding glass!
    title sez it all. removing liquefied core from the hull of my 77 Allison and i thought to look underneath. i may try to do the glass work while the boat is floating...
    Jun 2018
    Floating around
    Plenty of stories of hulls on roller trailers getting all tweaked out of shape from sitting on pressure points with soft cores. The trick is to build a good cradle and use the cradle to blueprint the hulls shape. A lot of hulls are not true from the factory due to heat curing warping and age and storage blah blah. When I did mine I used many techniques to get the hull sitting as true as possible before laying up glass. It made faring a lot easier and the hull runs tops.
  3. Likes NICE PAIR liked this post
  1. Core or stringers !!! what glass and why ??
    By tunnels in forum Fiberglass and Composites Discussion
    Last Post: 07-18-2012, 10:07 PM
  2. What Glass to use on Balsa core
    By 454man in forum Fiberglass and Composites Discussion
    Last Post: 07-24-2011, 09:40 PM
  3. Sealing the glass and core
    By boatwrench in forum Fiberglass and Composites Discussion
    Last Post: 03-10-2010, 03:54 PM
  4. Is it possible to forgo balsa core and glass in multiple layers of 18oz matt?
    By ernstudet22 in forum Fiberglass and Composites Discussion
    Last Post: 11-30-2007, 05:04 PM
  5. replace core, or just add 2 or 3 more layers of glass?
    By WATERWINGS in forum Fiberglass and Composites Discussion
    Last Post: 03-08-2005, 10:03 AM
