Results 1 to 3 of 3
    Sep 2017
    Ashland city tn
    Steering cable question
    I'm about swap out steering cables for longer ones, but i have teleflex ssc6272 which ends up being 12.6ft long and I found the exact cable but now they only sell in 1ft increments. I'm gonna be adding more set back and existing cables are stretched to max already, should I get 13ft or 14ft. I don't want bunch extra cause I hear that makes steering stiff. I. Gonna start with 2 extra inches and if it needs more I'll go to 4 more inches , I wanna say 13ft prob b ok but curious if 14ft would b to much. Thanks
    45 Post(s)
    Stiff / Drag Factors
    Quote Originally Posted by Merc 2.5 View Post
    It is sharp tight arcs (routing) that will create drag & stiffness. An extra foot should not be a problem.........
  3. Likes David - WI liked this post
    It sounds like you really need 13' now... before you add any setback, so 14' for sure.
  1. Checkmate steering cable question
    By carb a rator in forum Technical Discussion
    Last Post: 08-09-2019, 09:09 AM
  2. Cable steering question
    By Air Eddie in forum Technical Discussion
    Last Post: 10-16-2006, 09:29 AM
  3. steering cable question
    By speed in forum Props, Setup, and Rigging
    Last Post: 04-19-2005, 06:23 PM
  4. Cable steering Question ?????
    By sheetsabud in forum Technical Discussion
    Last Post: 03-30-2004, 10:06 PM
  5. Dual cable steering question
    By tombrown in forum Technical Discussion
    Last Post: 08-16-2001, 10:03 AM
