Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
    Nov 2020
    New Zealand
ID:	535003Click image for larger version.
ID:	535004Click image for larger version.
ID:	535005Click image for larger version.
    Now I can focus on the powerhead.
    Does anyone know how to load photos the right way up?Click image for larger version.
  2. Likes LakeFever, OnPad, 89LASER, NICE PAIR liked this post
  3. #17
    Jun 2018
    Floating around
    The only way I’ve had any luck with the photos loading correctly is to take them horizontally. Any pics taken with the phone held vertically rotate when loading up to the site
  4. Thanks NZ Sidewinder thanked for this post
    Likes OnPad liked this post
  5. #18
    right clic save (to your computer)
    double-clic (to show on your desktop)
    use rotate tool (then file-save) your desktop pic file should show the way you want it.
    load on site
ID:	535056. clic post quick reply @ bottom.
    If you want to enlarge pic, clic edit > select the pic, double clic pic, select size choice, clic save.
    Good Luck!
  6. #19
  7. Likes David - WI, 89LASER liked this post
  8. #20
    You do Nice work!
  9. Likes David - WI, LakeFever liked this post
  10. #21
    Nov 2020
    New Zealand
    Getting there.
    Here are a few photos from todayClick image for larger version.
ID:	535579Click image for larger version.
    That lower Cowl will probably get a tapered cut like a real race one.
    The power head is ready to assemble now.
    It was a mission to get the cage to rod bolt clearence right.
    The cages are stuffed in 5/16 inches but it's no use slotting the rod bolt head because top guided rods drift on the journal.
    So I had to make low profile rod bolts.
    It was simple in the end but took a while to get there.
  11. Likes motexas, LakeFever, 89LASER, NICE PAIR liked this post
  12. #22
    Nov 2020
    New Zealand
    Update
    Motor goes well.
    Running without a tuner.
    That means the distance from the base of the block to the open void of the midsection is 1/2 inch.
    Motor runs quiet.
    This is probably because of the water jets that are spraying the underside of the 1/2 inch thick base plate.
    The motor is running stock 2.0L small chamber heads cut .040.
    About 31-32 cc
    150psi.
    Reed cages stuffed in 24cc approx.
    Unusual port timing.
    .014 machined off tops of pistons because of over cut decks.
    Exhaust 1.500/1.550.
    Motor turns a 26p Ballistic through 7k easily.
    We have only done a few short runs.
    The motor is running stats and poppet but has 2 x 4mm jets in the base plate as well.
    These jets are in 1/4 bsp plugs that can be accessed from the bottom of the mid when gearbox is removed.
    Water pressure at speed is 15psi which I like.
  13. Likes OnPad, NICE PAIR, 89LASER liked this post
  14. #23
  15. Likes 89LASER liked this post
  16. #24
  17. Likes 89LASER, loop liked this post
  18. #25
    Rhode Island
    I love projects like these! Doin an awesome job, even if from down under! It’s on my bucket list to visit NZ
  19. Thanks NZ Sidewinder thanked for this post
  20. #26
    Nov 2020
    New Zealand
    Be sure to have a look at the k24 11Click image for larger version.
ID:	542430inch project on the diy 4 stroke thread.
    I'm working on it full time
  21. Likes NICE PAIR, 89LASER liked this post
  22. #27
    Nov 2020
    New Zealand
    This thread is a bit of a shambles.
    The outboard runs hard, got 88mph in slow water last outing.Click image for larger version.
  23. Likes NICE PAIR, 89LASER liked this post
  1. Mercury 15 HP race motor
    By Spectre22 in forum Technical Discussion
    Last Post: 05-14-2023, 02:00 AM
  2. Brand New Mercury 200 SST race motor
    By 3 STOOGES in forum Outboard Engines
    Last Post: 10-15-2016, 10:16 PM
  3. Mercury 115 complete 15inch motor
    By WhiplashedToyota in forum Outboard Engines
    Last Post: 02-10-2015, 10:09 AM
