Results 12,616 to 12,630 of 13312
10-02-2024, 03:37 PM #12616
10-03-2024, 12:12 PM #12617
Leon, Spain 1982.
Roger Jenkins - F1-V8 Team Carlsberg.
If you look close in the background you kan see my #1 OE class Burgess/AKAI boat cowling on the ground and my blue Mazda pickup.
10-04-2024, 01:26 AM #12618
Mike Butler
Top contributor
Rockford 1974.
10-04-2024, 06:27 AM #12619
Tom Percival leading Roger Jenkins.
10-05-2024, 01:43 PM #12620
Stephen Medaris
Australian equivalent to the T850 boats powered by a stock Evinrude SST60 and current Australian 1250cc Mono Speed record holder at just under 82MPH set in 1996. Did 88MPH with the OMC Mod 50 gear. These boats currently run in the 850cc Mono Class in Queensland powered by the OMC 75hp Stingers.
10-06-2024, 02:58 AM #12621
Mike Butler
Top contributor
Art in Clinton, Iowa 1972.
10-06-2024, 12:33 PM #12622
6000 RPM
- Nov 2006
- 1,735
- 15
- 179
- 85
- 776
- 42 Post(s)
Instigator liked this post
10-06-2024, 08:26 PM #12623
Ben raced Merc V6 before he went to the V8 series and then went back to racing in Champ boat after the V8 series died.
1970 15' Allison/135 Chrysler stacker
RC Mod-VP Boats
IMPBA District 13
NAMBA District 3
10-07-2024, 09:45 AM #12624
@Mark Poole ModVP
Correct and Ben also raced a Yamaha V6 in the Champ/PROP series a few years.
10-07-2024, 11:51 AM #12625
Evinrude - Johnson outboards. Facts, history, racing and OMC.
Jack Aylsworth
Evinrude Powered FIERO BOATCAR
Powered by an Evinrude 50hp looper outboard, this “boatcar” is likely better as a boat than it was as a car. Those who remember this little mid-engine Pontiac will recall that the 1984 introduction year cars had a propensity to catch fire. By mid-1987, the 1984 Fieros were catching fire at a rate of about 20 per month. Its Iron Duke engine dated back to 1977 and wouldn't fit as it was, so a redesigned sump and oil pan were used but the dipstick wasn't changed so the oil level would appear to be normal when it was in fact a quart low. Now add to this, defective connecting rods that only exacerbated low engine oil levels, and fires would result. In addition, a wiring harness mounted just above the exhaust manifold was also given to melting and starting electrical fires, and improperly-tightened head bolts would also sometimes crack the block and start a fire.(The Iron Duke engine has been removed from the boatcar.)
Note that the Fiero in “standard trim” does not float!
10-08-2024, 01:54 AM #12626
Burgess/Evinrude/Johnson FR 31M
UIM F3
Amberjack1234 liked this post
10-08-2024, 09:05 AM #12627
Thanks Fast on Water..
Can anybody tell us if these are still valid for free parking in Antwerp?
10-11-2024, 01:58 AM #12628
My brother Lennart Ström raced/tested the first new F3 engine in Martinique late 1987/early 1988. There was some issues OMC corrected and this is/was an extremely good engine used in UIM F3 racing for many years.
https://svera.se/blogg/the-omc-fr-31m-f3-race-engine-1988/
10-12-2024, 12:33 AM #12629
10-12-2024, 07:17 AM #12630Hustler 15' Wildcat / Merc 80
Hustler 13' Wildcat / Merc 80
Hustler 13' Picklefork (Experimental) / Merc 80
Hustler 16' Victor / Evinrude 85
Hustler 15' Tunnel / Evinrude X115
Hustler 17' Lark / Suzuki 140
Hustler 16' Victor
Hustler 16' Victor / JohnRude 135 (current and restored)
Hustler 15' Family Tunnel / Johnson GT115 (current project)
Hustler 16' Victor
Evinrude & Johnson Racing 1967+
By Mark75H in forum Outboard and Racing HistoryReplies: 46Last Post: 04-24-2023, 09:58 PM -
V8 Johnson/evinrude Outboards
By baassoc in forum General Boating DiscussionReplies: 23Last Post: 04-17-2020, 06:21 AM -
D and E Class OMC outboards, Johnson 60 and Evinrude 75
By smokin'joe in forum Outboard EnginesReplies: 0Last Post: 05-21-2017, 09:24 AM -
I made a video showing the tear down of a Johnson Evinrude 1975 nitro gear case
By regrp in forum Technical DiscussionReplies: 0Last Post: 10-02-2014, 09:07 PM
