Results 1 to 15 of 21
    Thunder Bay, Ontario Canada
    Speedometer questions
    My Allison Grand Sport has a pitot style speedometer. I want to replace it with a GPS speedometer. The pitot pickup bracket has broken and I don’t really want the pickup hanging down as they do.
    How accurate are the pitot style pickups? Is it possible that they could be as much as 10-15 mph off?
    Secondly, where do people usually mount the pickup antenna for a GPS speedometer on a grand sport? I’ve read that they need a clear view of the sky.
    Pekin, IL
    I had a Nordskog that was very accurate. Most pitots are not.
    Rock
    Team Junk
  3. Thanks Punteh thanked for this post
    Likes David - WI liked this post
    Lake Coochiching, Ontario
    My SS2000 pitot was dead on with a hand held gps up to 50 mph, and then grew increasingly optimistic. An indicated 94 was actually 90. Not bad.
    I have the gps antenna under the front deck of my SS2000, and my brother’s Grandsport also has the antenna under the front deck.
  5. Thanks Punteh thanked for this post
    Mar 2022
    Lake Travis Texas
    Nordskog and Gaffrig dry speedos are very accurate with in 1 or 2. The liquid gaffrig was the most accurate. The VDO is the most optimistic when i compared them to radar years ago.
    On antenna placement. They will work thru fiberglass. Mine is under my deck just forward of windscreen on my 28.
    Jim
  7. Thanks Punteh thanked for this post
    Apr 2023
    Long island, NY
    I have seen Pitot speedometers be off by as much as 15 MPH. They are more accurate at slower speeds. The faster you go the bigger the error can be. My Faria Beede GPS speedometer in my boat is exactly accurate to the GPS speedometer in my phone. It has an internal antenna inside the speedo case. No external antenna needed. Unfortunately, it only goes to 60MPH, so I need to replace it.
    May 2001
    Maine
    I like my Monster Livorsi GPS. It runs through a diagnostic/ calibration sequence every time the boat is started and updates very quickly. Antenna is mounted with 2 way tape on the dash.
    Aug 2021
    I have a cheapo "eling" GPS speedometer and it is accurate as phone. I also have pro comp marine GPS on another boat and looks better and more quality but same readout
    Mar 2004
    Brooklyn Park, MN
    my go pro is about 1 mph less than my Pro Comp Marine GPS in the dash of my Allison on top speed. Speedo in the boat says 103 and the go pro only says 102..... Why couldn't it be the other way! haha.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  12. Likes AlliStan liked this post
  13. #9
    Feb 2011
    HUDSON, FLORIDA
    remember there a two speed calcs, OTB over the bottom, and OTW oner the water, 1 example; GPS only measures OTB, if your river running GPS wil show faster with the current, where a pilot tube will show the speed the same, GPS doesnt calculate for the moving water for prop testing, a pilot tube speedo is the way,OTW. A 5 MPH current GPS will show say 55 downstream, the pilot tube will show 50 each directi,on. BOTH gauges are correct. actually the pilot tube measurement is a true OT W speed. went to USN classes ArtK. its hard to compare gps to pilot tube because of that variable.
  14. Likes AlliStan liked this post
  15. #10
    St. Amant, LA
    Quote Originally Posted by blackmaxonly View Post
    I have the same brand. I use it the analog gauge as reference since my Garmin has GPS speed on it as well.
    22R
  16. #11
    Aug 2021
    For $60 it's a steal, especially considering other proper brands go for $300+ without the GPS module. Mine is 3 years strong
    Apr 2023
    Long island, NY
    Kirchner is correct. except it is SOG (speed over ground) vs STW (speed through water) Here is a thing on it.
    Attached Thumbnails Attached Thumbnails Screenshot_30-9-2024_193455_www.simrad-yachting.com.jpg
  18. #13
    Feb 2011
    HUDSON, FLORIDA
    hey ski, you pretty smart guy i say OTB/OTW thats what us old mariners say, lol when comparing props, always use OTW if your splitting hairs
  19. #14
    May 2019
    Georgia
    Quote Originally Posted by KIRCHNER View Post
    remember there a two speed calcs, OTB over the bottom, and OTW oner the water, 1 example; GPS only measures OTB, if your river running GPS wil show faster with the current, where a pilot tube will show the speed the same, GPS doesnt calculate for the moving water for prop testing, a pilot tube speedo is the way,OTW. A 5 MPH current GPS will show say 55 downstream, the pilot tube will show 50 each directi,on. BOTH gauges are correct. actually the pilot tube measurement is a true OT W speed. went to USN classes ArtK. it's hard to compare gps to pilot tube because of that variable.
    So, that means back when Michael Dixon ran the 151 mph upstream in the Rocket, verified as the same by two GPS devices, and given the river current was at least 3 mph, he actually ran 154, or was it 152.5?
  20. #15
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by AlliStan View Post
    154 over the water
  21. Likes AlliStan liked this post
  1. Looking for new GPS Speedometer
    By DEN in forum Misc. Parts and Accessories
    Last Post: 04-29-2019, 05:43 AM
  2. WTB Speedometer
    By bow125106 in forum Parts Wanted
    Last Post: 04-03-2014, 01:07 PM
