Results 1 to 6 of 6
    I live in Prineville Oregon which is in the central part of the state
    260 re-nikasil cost?
    What is the going cost to re-nik all six cylinders on a 260 Block/
    Thanks, Carter
    Nov 2018
    Central Pa
    My dad sent a 280 block out a couple years ago, just needed nik in one sleeve and it took like 8 months to get it back. Didn't ask him how much it cost though.
    Apr 2023
    Long island, NY
    Call LA sleeve. Nikasil cylinder is on the 2 stroke order form. They have sleeves for everything. They have sleeves for 260's, 280's, 300 drag's, even bridgeports.Bridgeport. 1-800-822-6005 Tech line 562-945LASLEEVE-2-stroke-cylinder-form-2023_240913_004306.pdf-7578 LASLEEVE-2-stroke-cylinder-form-2023_240913_004306.pdf
    Jan 2020
    Pittsburg, Ca
    Should be like $2000 +/- 500. Go through a reputable engine builder/machinist, not straight to a big company like LA Sleeve. Its worth it to pay a couple hundred extra and have someone else deal with the guys re-plating in the case where it comes back with bad plating.
    Mar 2004
    Brooklyn Park, MN
    AND, aluminum coated sleeves are about 550-600 each if not more. so all 6 you got 3000+ in sleeves plus having to put them all in. Sometimes the sleeves are just fine, just the hole is 3.502-3 where it should be 3.501 from the factory or even less for some guys that build some screamers.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Susquehanna River, central PA
    Carter, I talked to Mag machine about two weeks ago and he told me that he charges $1600 as long as all the sleeves are ok and he doesn't have to do any other work.
    current rides-
    DCB Mach 22, twin 2.5
    2002 Bullet 20 XDC
    1991 Checkmate Pulse 225 Promax
    Jamis Zenith Elite road bike-one old man power
    past rides- four stv's, one 21 liberator, one mirage and a glasstron and a few pontoon boats and a duck boat.
    past power-2.5's, 200, 260,280, drag. 3.0 L-225, 300x
    No more dirtbikes!
  7. Likes 25two.stroke liked this post
  1. Help getting a Nikasil Job done
    By caymanpowerboats in forum General Boating Discussion
    Last Post: 11-22-2023, 08:08 PM
  2. Nikasil
    By ratso in forum Technical Discussion
    Last Post: 07-16-2019, 06:45 AM
  3. nikasil ?
    By mercrazy in forum Technical Discussion
    Last Post: 09-11-2003, 09:10 AM
  4. Nikasil sleeves
    By QUICKSILVER in forum Technical Discussion
    Last Post: 02-01-2003, 07:21 PM
