Results 1 to 6 of 6
Thread: 260 re-nikasil cost?
09-11-2024, 07:17 PM #1
What is the going cost to re-nik all six cylinders on a 260 Block/
Thanks, Carter
09-12-2024, 01:50 PM #2
5000 RPM
- Nov 2018
- Central Pa
- 135
- 15
- 105
- 32
My dad sent a 280 block out a couple years ago, just needed nik in one sleeve and it took like 8 months to get it back. Didn't ask him how much it cost though.
09-12-2024, 11:57 PM #3
Call LA sleeve. Nikasil cylinder is on the 2 stroke order form. They have sleeves for everything. They have sleeves for 260's, 280's, 300 drag's, even bridgeports.Bridgeport. 1-800-822-6005 Tech line 562-945LASLEEVE-2-stroke-cylinder-form-2023_240913_004306.pdf-7578 LASLEEVE-2-stroke-cylinder-form-2023_240913_004306.pdf
09-13-2024, 12:43 PM #4
Should be like $2000 +/- 500. Go through a reputable engine builder/machinist, not straight to a big company like LA Sleeve. Its worth it to pay a couple hundred extra and have someone else deal with the guys re-plating in the case where it comes back with bad plating.
09-13-2024, 01:21 PM #5
AND, aluminum coated sleeves are about 550-600 each if not more. so all 6 you got 3000+ in sleeves plus having to put them all in. Sometimes the sleeves are just fine, just the hole is 3.502-3 where it should be 3.501 from the factory or even less for some guys that build some screamers.
1973 Viper - sold
1978 Viking - sold
1995 XB02
09-13-2024, 04:56 PM #6
Carter, I talked to Mag machine about two weeks ago and he told me that he charges $1600 as long as all the sleeves are ok and he doesn't have to do any other work.
current rides-
DCB Mach 22, twin 2.5
2002 Bullet 20 XDC
1991 Checkmate Pulse 225 Promax
Jamis Zenith Elite road bike-one old man power
past rides- four stv's, one 21 liberator, one mirage and a glasstron and a few pontoon boats and a duck boat.
past power-2.5's, 200, 260,280, drag. 3.0 L-225, 300x
No more dirtbikes!
25two.stroke liked this post
Help getting a Nikasil Job done
By caymanpowerboats in forum General Boating DiscussionReplies: 2Last Post: 11-22-2023, 08:08 PM -
Nikasil
By ratso in forum Technical DiscussionReplies: 5Last Post: 07-16-2019, 06:45 AM -
nikasil ?
By mercrazy in forum Technical DiscussionReplies: 2Last Post: 09-11-2003, 09:10 AM -
Nikasil sleeves
By QUICKSILVER in forum Technical DiscussionReplies: 6Last Post: 02-01-2003, 07:21 PM
