Results 1 to 15 of 77
08-23-2024, 03:15 PM #1
2.0L 135 fatblock heads on 2.5L 200?
Heard good things about this mod. Anyone try it? I havent pulled the heads off my 135 yet to CC them but I am curious to hear your thoughts
08-23-2024, 06:00 PM #2
Make about 160 psi of compression with the smaller pocket.
LakeFever thanked for this post
08-23-2024, 06:23 PM #3
Sounds killer but it also sounds too high for pump gas, even with aces that much squeeze makes me nervous to try
08-23-2024, 06:30 PM #4
Yeah I would run 93 minimum with that compression.
08-23-2024, 06:58 PM #5
08-23-2024, 06:59 PM #6
Youre talking about the heads with the 6 lines around the plug holes and dowel pins at the ends?
08-23-2024, 07:04 PM #7
08-23-2024, 07:47 PM #8
From what I have heard, putting 2.0 heads on a 2.5 will give you about 160psi. Questionable for pump gas. But putting 2.4 heads on a 2.5 will give you around 140psi. Good for pump gas, just not regular.
08-23-2024, 09:58 PM #9
Late model 2L heads added 10lbs to my 2.5 engine, for a total of 120lbs. Kind of a disappointment. Still less than my factory 150 supermag that has 130lbs.
Idk if I have a bunch of junk or what, but the three 2.5/200's I own (with stock heads) have 110lbs of compression. With 5% or less leak down.
On a side note. I run 190lbs of compression in a chainsaw, and use pump gas.
David - WI thanked for this post
08-23-2024, 10:04 PM #10
I think I’d be trying another compression tester there onpad
08-23-2024, 10:12 PM #11
I think it's pretty accurate.
08-23-2024, 10:54 PM #12
OnPad liked this post
08-23-2024, 11:05 PM #13
Not exactly apples to apples, but heres a couple people that swapped 2L heads to a 2.4, and had similar results.
https://www.screamandfly.com/showthr...ssion-question
I used 1996 2l heads #18787c4 on a mid nineties 2.5. That had 18488c4 heads.Last edited by OnPad; 08-24-2024 at 09:30 PM.
08-24-2024, 12:00 AM #14
Lots of things affect cranking compression numbers... in northern Idaho, probably elevation? Add maybe 4% for every 1,000' above sea level... roughly?
08-24-2024, 01:43 AM #15
Yep, 2200ft probably puts me about 8-10 lbs down.
No bs about the 2 litre heads.....+10lbs is all I gained.
Used 18787 heads are kinda expensive. A good pair brings about what Skialot paid for his last engine
LakeFever liked this post
2.4 Fatblock which heads to cut? 2.4 or 2.5?
By coffeeguy in forum Technical DiscussionReplies: 5Last Post: 12-30-2014, 11:31 PM -
1991 2.4 Fatblock Cutting Heads and other cheap hp gains
By coffeeguy in forum Technical DiscussionReplies: 0Last Post: 12-27-2014, 01:54 PM -
Bridgeport, fatblock? what does this mean?
By tfrizz80 in forum Technical DiscussionReplies: 8Last Post: 09-27-2012, 04:13 PM -
Fatblock
By Jerry Millington in forum Technical DiscussionReplies: 12Last Post: 06-20-2006, 11:06 AM
