Results 1 to 6 of 6
Thread: Compression test older mercury
08-08-2024, 03:18 PM #1
Screaming And Flying!
- Miami,Fl
- 7,061
- 154
- 83
- 1480
- 383
I read with cdi ignition you should engage the kill switch to protect cdi. I know little about mercs. I never did on omc's. thanks Rick
08-08-2024, 03:23 PM #2
Use a starter button to jump the solenoid. Leave the ignition off.
pcrussell50 liked this post
08-10-2024, 11:44 AM #3
- Miami,Fl
- 7,061
- 154
- 83
- 1480
- 383
Another stupid question it's ok to hook to the 2 large lugs on the starter solenoid or is it better to use the kill switch and controls I know nothing about mercs and don't want to burn something up. Between a stuck lower unit and not knowing electrics I'm lost on this engine. thanks Rick
08-10-2024, 03:56 PM #4
Hot big lug and the small terminal with a yellow+red wire. Then you wont cause sparks, you are just activating the solenoid which is carrying the load.
08-10-2024, 05:43 PM #5
The thing why jumper lead or start box on solenoid is preferred is you can stand next to engine and hold the compression gauge. The two big lugs with a wrench will crank it but, will melt the wrench and make a big spark. A jumper lead as 25 suggests from big red to small yellow/red makes very little spark.
Jim
NICE PAIR liked this post
08-10-2024, 07:13 PM #6
- Miami,Fl
- 7,061
- 154
- 83
- 1480
- 383
A big thanks the lower is still stuck but everything else is so far checking out if nothing else I will have a big paper weight.
1985 Mercury Black Max 150 V6 Compression test
By dkpz64 in forum Technical DiscussionReplies: 8Last Post: 10-16-2023, 01:43 PM -
Compression test on a 92 2.5 mercury Is this true?
By 1fastg3 in forum Technical DiscussionReplies: 4Last Post: 03-31-2011, 07:48 AM -
Compression test 2002 Mercury 225 3l efi
By GTRMick in forum Technical DiscussionReplies: 4Last Post: 04-23-2008, 09:38 PM -
How do you test compression?
By Todd Tilley in forum Technical DiscussionReplies: 3Last Post: 09-14-2005, 10:23 AM -
2.4 compression test
By tozlakes in forum Technical DiscussionReplies: 1Last Post: 09-10-2005, 02:02 PM
