Results 1 to 2 of 2
06-28-2024, 08:18 PM #1
GT200 Identification confirmation help please
Johnson 200 identification
What is a J200STLENS? It has a GT200 hood on it.
It's a 20" lower. I think it's a 92
model. It's a open deck block with 333809 heads.
Ser.#003021654...
It appears to have the same carb part #"s as
A 225.
I'm just curious if I have a GT200.
Fresh water motor, tops of pistons
have OMC part # on them, would I see an oversize # by the part # or do I have original pistons? #432074.
So far I'm looking through a boroscope, so I can't Mike it now but will soon...
Pulled the heads, cleaned piston tops, same# as above and stbd exit. Or port...
Am I in the wrong discussion forum?
I've seen OMC Guys on here...
Thanks for your time.Last edited by oldschoolnc; 06-29-2024 at 06:33 PM. Reason: More information
06-29-2024, 07:36 AM #2
5000 RPM
- Oct 2011
- Ontario
- 429
- 47
- 54
- 553
- 159
- 8 Post(s)
Usually an oversized piston is stamped on it 0.010 0.020 0.030 at least on OMCs
oldschoolnc thanked for this post
Service manual confirmation for XR6
By hollowcd in forum Technical DiscussionReplies: 6Last Post: 09-28-2007, 06:43 AM -
Help with stator readings!Need confirmation!
By stoneman in forum Technical DiscussionReplies: 1Last Post: 09-10-2005, 03:31 AM -
Confirmation Of The Worlds Fastest Man On Water Coming To The Rumble!!
By Instigator in forum General Boating DiscussionReplies: 5Last Post: 08-02-2003, 09:46 AM
