Results 1 to 2 of 2
    Jan 2010
    north carolina
    GT200 Identification confirmation help please
    Johnson 200 identification
    What is a J200STLENS? It has a GT200 hood on it.
    It's a 20" lower. I think it's a 92
    model. It's a open deck block with 333809 heads.
    Ser.#003021654...
    It appears to have the same carb part #"s as
    A 225.
    I'm just curious if I have a GT200.
    Fresh water motor, tops of pistons
    have OMC part # on them, would I see an oversize # by the part # or do I have original pistons? #432074.
    So far I'm looking through a boroscope, so I can't Mike it now but will soon...
    Pulled the heads, cleaned piston tops, same# as above and stbd exit. Or port...
    Am I in the wrong discussion forum?
    I've seen OMC Guys on here...
    Thanks for your time.
    8 Post(s)
    Usually an oversized piston is stamped on it 0.010 0.020 0.030 at least on OMCs
  3. Thanks oldschoolnc thanked for this post
  1. Service manual confirmation for XR6
    By hollowcd in forum Technical Discussion
    Last Post: 09-28-2007, 06:43 AM
  2. Help with stator readings!Need confirmation!
    By stoneman in forum Technical Discussion
    Last Post: 09-10-2005, 03:31 AM
  3. Confirmation Of The Worlds Fastest Man On Water Coming To The Rumble!!
    By Instigator in forum General Boating Discussion
    Last Post: 08-02-2003, 09:46 AM
