Results 1 to 7 of 7
    Aug 2015
    Southeast
    225 promax - 260 mash up not getting fuel
    Recently bought a motor off a buddy and I'm having difficulty getting it running. It's a promax with 260 fuel injection adapted. I've seen the motor run on a prior boat so I'm confident the conversion is ok. I plumbed a bosch 044 pump and return. Using the same bosch fuel regulator that was on it. Don't have a pressure guage yet, but will tomorrow. The pump runs, return line is dumping fuel back to the tank. Motor will start on ether. Absolutely nothing on just the fuel pump and the plugs are dry. I'm convinced the injectors aren't firing. It has a brucato box. I plugged in a stock promax box and get the same result. I spread all the pins in the harness thinking maybe I wasn't getting a good connection on something. No help.
    Any ideas on what may cause fhe injectors to not fire? Or any other ideas? The motor was run in December and I was there.
    Thanks for any input.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship" Sold
    Blazer 650 Pro Tour
    30ft Cobra with Triple 280's
    Feb 2011
    HUDSON, FLORIDA
    hey kurt, are you sure you have ignition on? small red wire inline fuse
  3. Likes Mrzip liked this post
    Jun 2018
    Floating around
    You can get noid lights to plug into the harness and see if the injectors are being commanded to open
    Apr 2010
    Jacksonville, Florida
    Does the motor have a Mercury Stator? My injectors were not firing either with Brucato. Brucato checked ok, come to find out the CDI Stator wasn't delivering the correct voltage. New A-36 stator, problem solved.
    2016 Allison Grand Sport
    225 Promax
    Aug 2015
    Southeast
    Thanks guys.
    Yes, ignition wire is ok.
    Will check into the noid lights and check the stator. Maybe the stator has gone bad. It ran in December and was removed from boat shortly after. But stuff can quit so I'll check that out. Thank you.
    Blazer 650 Pro Tour
    Aug 2015
    Southeast
    As usual, it was something simple. The purple wire that powers the computer had come unplugged. Starts right up now.
    Blazer 650 Pro Tour
  8. Thanks LakeFever thanked for this post
    Likes LakeFever, wcarlyle, Baker343 liked this post
    Pekin, IL
    Love a happy ending.
    Rock
    Team Junk
  10. Likes LakeFever, Jim Speros liked this post
  1. Replies: 1
    Last Post: 10-11-2021, 08:04 PM
  2. Not quite a V4 140 but not an 85 Just a mash up
    By spybot in forum Technical Discussion
    Last Post: 08-02-2017, 09:08 AM
  3. Lower Unit Mid section mash up Question
    By Krazymaan in forum General Boating Discussion
    Last Post: 07-07-2016, 10:52 PM
  4. 300 Promax Fuel ECU
    By Bkeenom in forum Misc. Parts and Accessories
    Last Post: 01-11-2016, 10:11 PM
