Results 1 to 15 of 20
Thread: Project - Ultimate Gambler
05-30-2024, 01:59 PM #1
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
Figured I would start a project thread...
1991 Gambler Intimdator Dale Earnhardt edition
1998 Merc 200 efi
Project started actually 10 years ago when I first bought the boat.... it was in rough shape, very faded, hull torn up, had a horrible fish finder screwed on top the drivers console.. crusty v140..it was rough
I Did a restoration over that first fall/winter, fixed numerous chips on hull running surface, wet sanded and buffed the whole thing, stripped all hardware and bogus wiring, rigged the merc and basically ran it like that till now.
I realized it had water intrusion last couple years, and it really hit a tipping point where it's either run it into the ground or make it right.
So I set out fall 2023 to get it going. I'll make a few posts to show progress up to current.
Making this thread for motivation and accountability, and to give back to Scream and Fly
Instigator thanked for this post
05-30-2024, 02:12 PM #2
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
It will look about the same when it's done which is crazy but it will be in it's ultimate form.. or my vision of that I guess... the goal is to have it stripped light as possible, no trolling motor, liner totally sealed out, no points of intrusion at all, top cap bonded to hull, no rivets or screws. Main thing is ditch the fuel tank for an aluminum cell, and re-engineer how it mounts. Bad factory design with huge heavy tank, caused liner to Crack and take on water
Motor is good to go, it has ccms reeds and stuffers, 32cc heads, timing 24 deg, 260 exhaust divider, run 93 rec fuel Pushed this bathtub full of water to 70mph last time out used to see 76 in it's prime
05-30-2024, 02:24 PM #3
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
First thing was I had to get the barn door widened to fit the boat.. it was a foot shy of course. Made sure it'll be able to fit a 22 cat someday.
Had the joists all redone in 2x12 free spanned so no columns. Had them tripled up in 2 locations, to support traversing hoists.
That was a great day backing the boat in
05-30-2024, 02:40 PM #4
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
Lots of detailed grinding work over last few weeks. Plan was to cut out rear 1/3 of liner for a few reasons
A) didn't think it would be wet forward of there
B) that cut line and subsequent glasswork is all hidden by the top cap
I ground it down to substrate before cutting it out, figuring that would be easiest route. The liner was paper thin in some areas so I laid some csm to reinforce it for removal. That did prove to be necessary, but also counter productive in that it glued it down to the foam, requiring some serious prying and pulling
05-30-2024, 02:46 PM #5
Lot of work but in the end it will all be worth it.
RockTeam Junk
05-30-2024, 03:26 PM #6
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
Thanks Rock,
That's what I'm hoping.. Its always run very stable and quick, I can't wait to see what it will do. Just gotta get over the teardown hump.....
05-30-2024, 06:23 PM #7
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
Back portion of liner is out as of today.
Whole rest of the liner needs removed, the entire thing is saturated. Which I suppose is good news, going to take out a ton of weight.
... the aroma of wet foam... holy smokes
89LASER liked this post
05-30-2024, 06:49 PM #8
Good Lick, as Rock said lots of work, but will be Awesome when completed. Look forward to seeing the work and finished product.
MO
NeedOne thanked for this post
05-30-2024, 09:16 PM #9
Interesting to see how Gambler built their boats. Looks well thought out, and very strong!!
Thanks for posting your project.
05-31-2024, 08:25 AM #10
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
Thanks Onpad, yeah it really is solid.. unfortunate the few design misses were of the leaking variety. But it's all good, I've had so much fun in this boat.
05-31-2024, 08:36 AM #11
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
Designed this new skid planer for the jack plate, based off some pics on S&F,, 10 ga. SST. If anyone wants the print I can provide it, fits 10" setback hydrodynamics rapidjack (16 in. Inside the mounting flange)
OnPad liked this post
06-01-2024, 07:30 AM #12
Always liked those boats!
Will be a cool classic when done.
Thx for sharing.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
06-04-2024, 07:34 AM #13
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
06-04-2024, 07:47 AM #14
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
Worked on some fun stuff over the weekend...
Disassembled jackplate, cleaned with goof off professional grade, then scotch Brite and vinegar/water 50/50. Then rubbing alcohol and cleared with UV stable clear laquer. Similar for hot foot... Sand blasted, tuned action & cleared.
I have wanted an offshore mid for a loooong time... got this nice ridgeback from a S&F member.Last edited by NeedOne; 06-04-2024 at 07:49 AM.
06-05-2024, 04:58 AM #15
Have Not read what you did if anything to support the hull?
With everything you’ve cut out of it that hall will now be as flimsy as a potato chip!
I have restored many, down to that level and that is an important step.
If you do it while sitting on the trailer you are assuming the bunks are straight and level
Which they almost certainly are not.
On a boat that size I normally build a jig, level and square it, bolt it to the floor of my shop, and then strap the hull to it.
If the jig is true, it is common for the boat to not sit flat on it, as in there is twist in from its years of use/abuse.
Many bypass the step with disastrous result. The faster it is the worst those effects will be.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
rock liked this post
My ultimate project?
By Dixon Smith in forum General Boating DiscussionReplies: 91Last Post: 01-11-2015, 10:43 PM -
The Ultimate Sleeper
By mirage243 in forum The Scream And Fly LoungeReplies: 17Last Post: 06-05-2012, 09:14 AM -
This Is The Ultimate Bs!!!!
By The Big Al in forum The Scream And Fly LoungeReplies: 49Last Post: 03-05-2008, 12:53 AM -
The Ultimate Engine
By Eagle One in forum General Boating DiscussionReplies: 15Last Post: 10-14-2003, 09:49 PM
