Results 1 to 7 of 7
06-04-2024, 07:27 AM #1
6000 RPM
- Aug 2015
- Southeast
- 1,288
- 139
- 124
- 58
- 793
225 promax - 260 mash up not getting fuel
Recently bought a motor off a buddy and I'm having difficulty getting it running. It's a promax with 260 fuel injection adapted. I've seen the motor run on a prior boat so I'm confident the conversion is ok. I plumbed a bosch 044 pump and return. Using the same bosch fuel regulator that was on it. Don't have a pressure guage yet, but will tomorrow. The pump runs, return line is dumping fuel back to the tank. Motor will start on ether. Absolutely nothing on just the fuel pump and the plugs are dry. I'm convinced the injectors aren't firing. It has a brucato box. I plugged in a stock promax box and get the same result. I spread all the pins in the harness thinking maybe I wasn't getting a good connection on something. No help.
Any ideas on what may cause fhe injectors to not fire? Or any other ideas? The motor was run in December and I was there.
Thanks for any input.Bullet CC w/ 225 Promax - Sold
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship" Sold
Blazer 650 Pro Tour
30ft Cobra with Triple 280's
06-04-2024, 07:42 AM #2
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,947
- 596
- 100
- 519
- 629
hey kurt, are you sure you have ignition on? small red wire inline fuse
Mrzip liked this post
06-04-2024, 08:17 AM #3
You can get noid lights to plug into the harness and see if the injectors are being commanded to open
06-04-2024, 08:39 AM #4
Team Member
- Apr 2010
- Jacksonville, Florida
- 91
- 10
- 24
- 90
- 74
Does the motor have a Mercury Stator? My injectors were not firing either with Brucato. Brucato checked ok, come to find out the CDI Stator wasn't delivering the correct voltage. New A-36 stator, problem solved.
2016 Allison Grand Sport
225 Promax
06-04-2024, 09:48 AM #5
6000 RPM
- Aug 2015
- Southeast
- 1,288
- 139
- 124
- 58
- 793
Thanks guys.
Yes, ignition wire is ok.
Will check into the noid lights and check the stator. Maybe the stator has gone bad. It ran in December and was removed from boat shortly after. But stuff can quit so I'll check that out. Thank you.Bullet CC w/ 225 Promax - Sold
Blazer 650 Pro Tour
06-06-2024, 05:52 AM #6
6000 RPM
- Aug 2015
- Southeast
- 1,288
- 139
- 124
- 58
- 793
As usual, it was something simple. The purple wire that powers the computer had come unplugged. Starts right up now.
Blazer 650 Pro Tour
06-06-2024, 09:11 AM #7
Love a happy ending.
RockTeam Junk
Looking for: 250xb fuel ecu, 300 promax ignition ecu and 300 promax heads
By HST_ONT in forum Parts WantedReplies: 1Last Post: 10-11-2021, 08:04 PM -
Not quite a V4 140 but not an 85 Just a mash up
By spybot in forum Technical DiscussionReplies: 13Last Post: 08-02-2017, 09:08 AM -
Lower Unit Mid section mash up Question
By Krazymaan in forum General Boating DiscussionReplies: 1Last Post: 07-07-2016, 10:52 PM -
300 Promax Fuel ECU
By Bkeenom in forum Misc. Parts and AccessoriesReplies: 1Last Post: 01-11-2016, 10:11 PM
