Results 1 to 5 of 5
    May 2009
    2000 Mercaha up tilt/trim intermittent
    Trims down every time easy peasy.
    Does not always trim up, but sometimes. Solenoids click every time, either from the binnacle switch or the switch on the cowl. Makes me think there’s a weak connection somewhere.
    Gonna guess corrosion on the high current contacts inside inside the solenoid as the likely culprit. When it works it works normally.
    This motor has three solenoids arranged vertically, near the front, on the starboard side. It feels like each solenoid clicks, when I activate a trim switch.
    2000 Merc/Yamaha 90 FourStroke.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
    Jan 2020
    Pinole, Ca
    Change em both. Not solenoids really...relays. Yes they both click when you trim either direction. Reversing polarity on both legs.
  3. Thanks pcrussell50 thanked for this post
    Likes pcrussell50 liked this post
    May 2009
    I’m out on a trip away from my Merc manual… there are three… relays… stacked vertically one above the other. Do you know off the top of your head, which two are for trim?
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    Mar 2022
    Lake Travis Texas
    blue and green wires are for trim. The other relay likely has red or white.
    Jim
  6. Thanks pcrussell50 thanked for this post
    May 2009
    Quote Originally Posted by Jim Speros View Post
    Thank mate. So standard Mercury colours. I wasn’t sure since it’s a Yamaha Merc and I’m away on a work trip and can’t get to my manual until Wednesday morning.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
  8. Likes 25two.stroke liked this post
  1. 2000 200 EFI intermittent ?spark? Issue
    By KZaker in forum Technical Discussion
    Last Post: 05-14-2020, 11:44 AM
  2. Tilt N Trim won't Tilt N Trim on 2006 Tohatsu MD 50 B
    By ZO6 in forum Technical Discussion
    Last Post: 12-31-2018, 09:29 PM
  3. OMC Tech: 2000 225HO (carbureted) intermittent misfire
    By Bulletpilot in forum Technical Discussion
    Last Post: 11-05-2017, 11:40 AM
  4. mercaha
    By NOWAKE in forum Technical Discussion
    Last Post: 12-28-2009, 11:10 PM
  5. IT'S a MERCAHA
    By Greg Moss in forum General Boating Discussion
    Last Post: 04-11-2002, 02:52 PM
