Page 16 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 226 to 240 of 250
  1. #226
    May 2020
    Does the prep-sol degreaser/dewaxer dry fast like acetone and will it agree with the duratec primer and gel I already have on the boat?
  2. #227
    Quote Originally Posted by Jmr1974 View Post
    Ya no problem, not quite as volatile as acetone but dries quick. Another thing about washing with acetone is it may soften the base your washing, the final wash products are less aggressive. But forget all this stupid tech stuff. The REAL reason you can't get a good finish on this boat is because God is punishing you for not making it metalflake. Probably your dog even hates you now
    Jun 2018
    Floating around
    hahahha you win the internet today
  4. #229
    May 2020
    Lol, yeah I’m going with a solid color, that’s what the boat was originally anyway except red. I would really have a mess on my hands if I did metal flake with all the problems I’m having.
  5. #230
    May 2020
    Well good news and bad news, the big compressor worked much better on the other half of the boat. I still got some fish eye but nowhere near as much. What I ended up doing was let the gel I sprayed kick then I went put a drop of gel in the fish eyes hopefully it works, I’ll find out when I sanding.
  6. Likes LakeFever liked this post
  7. #231
    Nov 2003
    Portsmouth VA
    We often used denatured alcohol for final wipe-down.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  8. #232
    May 2020
    For anyone who has applied gel coat with the duratec additive the way I did (sprayed) what grit sand paper did you start with to knock down the orange peel? I have 400,600and 800. Does it need to be wet or dry? Also I have to knock down all the gel droplets that I put on the fish eye areas, it’s much higher than the rest of it, how should I go about that? Maybe a Dremel? I’m guessing that I need to tread lightly on the sanding/buffing process as to not go all the way thru the gel…
  9. #233
    May 2020
ID:	533007Spent most of today fixing the fish eyes. Yesterday I was able to put a drop of gel into them right after I sprayed. On the other side of the boat the gel was already cured so I used a Dremel to clean out the fish eyes then mixed some gel and put a drop in each one with the little tool in the pic. Once the gel cured I used a finger sander to flatten them out, I left them just a tad higher than the orange peel in hopes that when I start the sanding/buffing process everything will blend out. Figured by doing this I won’t have to sand off the whole gel coat again and risk more fish eye.
  10. #234
    May 2020
ID:	533354Click image for larger version.
ID:	533355 Huge victory today! Just finished spraying my hull for the 3rd time today and not one single fish eye! The problem ended up being the 50/50 duratec high gloss and gel mix was too thin on my first 2 attempts. This time I went with more gel and less duratec and it worked mint and still sprayed great out of the gun. Now I just gotta finish my running surface with the gator glide and flip the boat. The gel I sprayed today should be pretty easy to cut and buff seeing as the orange peel is very minimal.
  11. Likes LakeFever, motexas, 89LASER liked this post
  12. #235
    Jun 2018
    Floating around
    Looking good!
  13. #236
    May 2020
    Looking good!
    Thanks, it feels good! I actually sprayed half the boat yesterday and the other half today. On the half I sprayed yesterday I started to sand a little while ago with 600 grit, it made short work of the orange peel until it started to rain on me.
  14. Likes LakeFever liked this post
  15. #237
    May 2020
    Attachment 533573 She’s starting to shine!
  16. #238
    May 2020
    not sure why the pic doesn’t show up…
  17. #239
    Jun 2018
    Floating around
    I think that happens when the pic doesn’t fully load onto the site when you’re posting. Probably work ok if you try again
  18. #240
    May 2020
  19. Likes LakeFever, 89LASER liked this post
  1. 1977 Ventura II Race Boat For Sale
    By JWTjr. in forum Hulls up to 20'
    Last Post: 09-30-2014, 04:59 PM
  2. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  3. How fast?1977 ventura II
    By busa198 in forum General Boating Discussion
    Last Post: 03-01-2010, 08:04 PM
  4. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  5. Ventura set up ?s
    By zzzman in forum Props, Setup, and Rigging
    Last Post: 11-15-2006, 07:41 PM
