Results 1 to 15 of 16
Thread: 300R tune
    Lake Coochiching, Ontario
    300R tune
    https://www.speedmastermarine.com/pr...0-outboard-ecu
    Is there someone here with deep pockets ready to try this? Or is this a known good already? $6K Cdn, works out to $4384 in real money
    SR360 OUTBOARD ECU
    SR360 Stand Alone Engine Control Unit
    Designed for Mercury 300R 4.6L V8 Outboard
    Utilizes all of the OEM Sensors & Emissions Control Devices
    Plug & Play Installation - IP67 Water Resistance
    Premium 93 Octane Fuel Required
    360 HP @ 6500 RPM (+60hp)
    319 lb/ft @ 4450 RPM (+20 lb/ft)
    7000 RPM Rev Limit (+600 RPM)
    Professional Installation Required
  2. Thanks rsess thanked for this post
    PARADISE /Naples
    Strictly for racing, silly boy...
    *For Closed Circuit Sanctioned Event Use Only*
    SOCAL, the land of 75* and sunny!
    Quote Originally Posted by CUDA View Post
    So is the decatted Comp Werkes exhaust and Rexxer tune on my Hypermotard moto. Rules are for suckers, and it's only illegal ifn ya get caught.
    But that's a lot of skrilla for 60 HP and maybe a few MPH.
    PARADISE /Naples
    In Super Stock racing with the 300r, they pass out and collect ECUs before and after the race to prevent Hanky Panky
    My ZG1400 is on its third and last "Flash" with ZX exhaust.
    My diesel pickups have all been deleted and programmed.
    Even my KTM dirt bike has a Piggyback
    I understand.
    Jan 2021
    Lake Muskoka,Ontario
    Shutdown within 3 hours by Mother Mercury!
    Quote Originally Posted by David View Post
    SR360 OUTBOARD ECU
  7. Thanks CUDA thanked for this post
    NYC/FL/NH
    I understand.
    They do not hand out ECU's before super stock races for the 300R. They did scan us both in and out last weekend.
  9. Thanks scott reierson thanked for this post
    Likes Ryan Beckley liked this post
    Apr 2010
    Indian Lake Ohio
    Quote Originally Posted by cowisl View Post
    Thanks for the clarification and if I follow things right you won at loto correct? If so congrats! The Steele team had a post about running an ECU flash that doesn't go into guardian as easy, is that a real thing?
    PARADISE /Naples
    I misunderstood, that was the procedure when they were using the 300XS, The 4-stroke is harder to get at, so quick swaps can't happen.
    Congratulations, I was expecting Jackhammer to catch up. I saw one turn; they tried to make an inside move on you,
    They got hosed down and lost lots of ground that they just couldn't make up in the calmer water,
    Interesting, the DWs seem to do better in smoother water, the Victory boat, with its large steps, likes ruffer to get loose
    It's a Great class. Good to see a fresh face in the winners circle.
  12. Likes Ryan Beckley liked this post
  13. #9
    NYC/FL/NH
    Quote Originally Posted by Lake rat Skater View Post
    Thank you. Correct- Mercury gives the race teams a race "tune"
    NYC/FL/NH
    Thank you!
    PARADISE /Naples
    I know nothing about the above, but where there is a will, there is a way. In a pure stock class, one little change, as stated.
    over a long course makes all the difference. I've heard other rumors about another team, It's Human Nature.
    In outboard drag racing 20 years ago, a guy got caught pumping water in and out of his boat to make weight
    I highly doubt he's the only one that's used that.
    Someone might figure out how to change the signal to the ECU to change it's commands.
    The RPM record is remembered, not sure about Timing advance ect.
  16. #12
    The "race tune" is a touch of timing. The motors are making 330+ hp stock so spending that money for a 30hp gain (if it was real) is a pricy increase. Its going to take more than a tune to make real power potential from a 300R.
    Thank you!
    You guys did a great job running and maintaining the perfect line. It didn't appear that Jay ever pulled back-I am guessing you guys have a really good set of 31s to pull off what you did.
    Hats off to both of you guys-it was very fun to watch
  18. Likes cowisl liked this post
  19. #14
    Jan 2003
    aalsmeer
    If you take the time
    https://www.ampefi.com/product/ms3pr...gement-system/
  20. Thanks CUDA thanked for this post
    Likes CUDA liked this post
  21. #15
    Apr 2010
    Indian Lake Ohio
    Thank you guys for the info, cool to know there is a "race" tune even if it just relaxes guardian some. Do you guys still think a 15" 300r is on the horizon?
  1. How to tune this OMC v6 225 hp???????
    By Flabenk69 in forum Technical Discussion
    Last Post: 03-03-2019, 10:53 PM
  2. Wow!!!! you can tune a OMC this much !!!!
    By spybot in forum Technical Discussion
    Last Post: 02-16-2018, 03:40 PM
  3. Name that Tune???
    By raceboatrus in forum General Boating Discussion
    Last Post: 10-25-2010, 03:01 AM
  4. tune up
    By tmull44 in forum Technical Discussion
    Last Post: 06-27-2004, 09:41 PM
