Results 1 to 7 of 7
    Jun 2018
    Floating around
    200 2.5 connecting rod, heat discolored bad, thoughts?
    Surfaces seem ok nothing galled all smooth still. Wanted to check with you guys first see what you think of this rod. Safe to run?
ID:	532853 Click image for larger version.
    Pekin, IL
    As long as the ends are good and it's straight.
    Rock
    Team Junk
    Aug 2021
    Osteen/Deltona, FL
    I've taken rods out of good motors that are that color. It's something with the coating. I'd be more concerned if the bearing ends were purple, which they don't appear to be.
    83 Vking 150 Mariner 2.5L
  4. Likes NICE PAIR liked this post
    Jun 2018
    Floating around
    Four stroke press pins look like this after heating so I figured it was fine but I don’t know jack about these rods. If they are heat treated or whatever. For what it’s worth this was my second tight holes rod. Very slight discoloring here and I added a pic of the end of the one above it’s the blueish date I say purply one
ID:	532867 Click image for larger version.
ID:	532868 Click image for larger version.
    Apr 2023
    Long island, NY
    They look fine. I would use them. They look like every rod in every merc outboard I have ever taken apart.
  7. Thanks LakeFever thanked for this post
    Right, because they bury them in copper or something so they harden the ends but not the beam when they're heat treat.
    I fear all we have done is to awaken a sleeping giant and fill him with a terrible resolve.
  9. Thanks LakeFever thanked for this post
    Jun 2018
    Floating around
    Good info thanks gents. I did some further investigating last night trying to understand the nature of these rods. I reached out to Jay Smith who provided excellent advice on how to check the rods before installing and discovered two of these rods are unusable. The cracked cap doesn’t set down perfectly concentric. There is a very, very slight offset at the crack inside the bearing race area I can catch it with my thumbnail. The two bad rods are not the discolored ones either so I got super lucky there or it would have been bye bye crank and motor in short order. Fortunately I have a couple spare motors so I’ll be tearing one down today to get some more rods from.
  11. Likes NICE PAIR liked this post
  1. The heat is on
    By racervboat in forum The Scream And Fly Lounge
    Last Post: 08-10-2018, 04:45 AM
  2. "Discolored" white boat...
    By Vinnie in forum Detailing and Care
    Last Post: 07-01-2009, 09:41 PM
  3. Mercury Tech: over heat ???
    By afr in forum Technical Discussion
    Last Post: 03-25-2009, 04:58 PM
  4. Discolored wrist pins..
    By Hydro-T20 in forum Technical Discussion
    Last Post: 10-02-2006, 02:37 PM
  5. Egt-how Much Heat Is Too Much ?
    By liberatorx2 in forum Technical Discussion
    Last Post: 06-09-2003, 02:46 PM
