Results 1 to 3 of 3
Thread: 57 Johnson 18 HP Swivel Pin
05-22-2024, 09:37 AM #16000 RPM
- Nov 2006
- 1,512
- 14
- 132
- 71
- 633
- 35 Post(s)
I've rescued a 1957 Johnson 18 HP from outdoor storage yard after sitting outside for 16 years. Problem is the mid section swivel pin is nearly frozen. Only way I can get full sweep steering is with a dead blow mallet, torch and lots of AeroKroil. Exploded assembly diagrams on internet show bushings/shell bearings on each end of the swivel pin. I don't want to do any serious torch work on the swivel / tilt casting and ruin the Holiday Bronze (brown) paint. YouTube video shows somebody using acetone / ATF injected thru grease nipple using a pump grease gun. Does this work? Any other tricks / methods?
05-22-2024, 12:12 PM #25000 RPM
- Feb 2002
- The great corn desert of Iowa
- 300
- 42
- 200
I’ve used kerosene and naphtha before. I unscrewed the end off of a grease gun and McGyvered it up to a large syringe. I wasn’t concerned about the paint and can’t really tell you how it would affect it.
1971 Sidewinder 14 SS w Johnson 90 v-4
1959 Texas Maid Falcon w Mercury Mark 35A
1981 Sylvan Sportster w Johnson 85 v-4
2006 Harris pontoon with a Yamaha 90
1969 Sunfish sailboat
05-22-2024, 12:41 PM #36000 RPM
- Nov 2006
- 1,512
- 14
- 132
- 71
- 633
- 35 Post(s)
Free 'd!
Freeeed! This morning after 4 days of AeroKroil soaks and light torch cycles. Torch heat applied before and after motion cycles and AeroKroil applied for soak in after each motion / torch cycle. Patience prevails and expect 3-4 days of soak / heat / motion cycles to produce results. Motion cycles began with dead blow mallet hits to something robust like the steering & carrying hoop (NOT the steering arm!).
NICE PAIR liked this post
Looking for Johnson / Evinrude V8 20" Swivel Bracket and Exhaust Housing (Midsection)
By jwbissett in forum Parts WantedReplies: 2Last Post: 05-17-2021, 08:47 AM -
ISO Johnson/Evinrude 20" V8 swivel bracket
By LiquidSpeed in forum Outboard EnginesReplies: 2Last Post: 05-04-2017, 08:20 AM -
OMC johnson 225 v6 vro technical date(comp. 225hp 2tEvinrude-suzuki-Johnson-mercury)
By Flabenk69 in forum Technical DiscussionReplies: 6Last Post: 05-02-2015, 11:27 AM -
Swivel
By xskeetshooter in forum Parts WantedReplies: 0Last Post: 12-15-2014, 10:01 AM -
OMC Tech: Mixing and matching Johnson 140 powerhead to johnson 200 mid section and lower unit
By stonebreaker in forum Technical DiscussionReplies: 11Last Post: 04-16-2012, 07:24 PM
