Results 1 to 6 of 6
05-20-2024, 08:04 AM #1
1997 johnson 90 hp water psi gauge hookup
I dont mess with omc very much. Where do you hook water psi tubing to? I read that you are supposed to put a "T" fitting into the tell tale hose. That doesnt seem like it would work with a crap. water will flow to the least resistance. Any input appreciated.
05-21-2024, 06:22 PM #25000 RPM
- May 2004
- Eastern PA
- 598
- 29
- 56
I wanted to add a water pressure gauge to my OMC 2.6L and posed this question to a very reputable OMC guy from this site…his suggestion was to T into the water dump hose as you mentioned. I bought the kit, cut the line a few inches from where the dump exits the head, inserted the T fitting and that was it. I understand your skepticism but that’s what I did…
05-22-2024, 05:20 AM #3
05-22-2024, 06:12 PM #45000 RPM
- May 2004
- Eastern PA
- 598
- 29
- 56
Yes. It seemed to work fine. In fairness, I didn’t have a chance to run it for a long time because it was a brand new rig job (engine, steering, shifter, gauges, etc.) on a complete restoration so I had a lot of parts that I was checking and adjusting. I was testing on a flush kit but appeared to have about 10 pounds of pressure (I believe) and when I revved the motor the pressure increased with RPM increases.
05-23-2024, 06:50 AM #5Scream And Fly VIP
- May 2001
- Hickory NC
- 5,587
- 18
- 250
- 204
- 467
- 4 Post(s)
The 60 degree engines have a brass plug into the water jacket, remove plug and install water pressure fitting. The some of the 90 degree engines use a T while others do not.
05-23-2024, 07:07 AM #6
This is a 90 deg motor. Has a plastic elbow towards the bottom of water jacket closer to the starboard side. I will just use a "T" fitting. Thanks
Mercury Tech: Promax water pressure gauge hookup
By CHICKENHAWK in forum Technical DiscussionReplies: 2Last Post: 07-10-2017, 08:48 PM -
OMC water psi gauge hookup question
By at100plus in forum Technical DiscussionReplies: 4Last Post: 06-28-2014, 05:38 PM -
Water pressure gauge hookup on looper
By Lockjaw in forum Technical DiscussionReplies: 0Last Post: 04-28-2006, 08:46 PM -
Water PSI Gauge hookup
By LaserLTV in forum Technical DiscussionReplies: 0Last Post: 07-22-2002, 05:34 PM
